Tinman's '51 Cabover lowbuck build
Old 09-14-2014, 06:38 PM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
She's got glass....
I started installing the glass.....
The front and back went in pretty easy, but those little 1/4 windows were a bugger. Looks good with some windows!
Now on to the door/vent glass...fun!
  #347
Old 09-14-2014, 06:47 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Jolly Roger Joe is offline
Nice job on the windows!
  #348
Old 09-14-2014, 07:32 PM
bobbytnm's Avatar
bobbytnm
bobbytnm is offline
Roast em' if you got 'em
Received 3,838 Likes on 1,837 Posts
You've made some pretty good progress. Its really starting to look like something now that you have glass installed.
Nice!
  #349
Old 09-15-2014, 11:01 AM
arctic y block's Avatar
arctic y block
arctic y block is offline
Did the back glass install
from the inside?
  #350
Old 09-15-2014, 01:22 PM
FortyNiner's Avatar
FortyNiner
FortyNiner is offline
from the inside?
Yup, BB rear window from the inside - windshield from the outside.
  #351
Old 09-15-2014, 06:47 PM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
yes, and the 1/4 widows also went in from the inside as they are cut down rear window openings
  #352
Old 09-15-2014, 07:03 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
Nice job on the rubber for those quarter glasses! I can't find the seam?? Nice view of the dash thru the quarter, too!
  #353
Old 09-15-2014, 07:44 PM
r_reed's Avatar
r_reed
r_reed is offline
what ross said.
  #354
Old 09-15-2014, 09:27 PM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
HAha, the other side didn't turn out quite as good.....which is why I took the pic on this side.
The seam is at 9 o'clock.......
  #355
Old 09-16-2014, 12:11 AM
52 Merc's Avatar
52 Merc
52 Merc is offline
Received 2,449 Likes on 1,396 Posts
Was the quarter glass harder to install because it was smaller and less flexible? Or some other reason I'm not thinking of?
  #356
Old 09-16-2014, 10:55 AM
tractormanbill's Avatar
tractormanbill
tractormanbill is offline
tractorman
Do you really need to put sealer on the front & rear glasses or can you just put them in and let the rubber seal?
TractormanBill
  #357
Old 09-16-2014, 02:08 PM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
TractormanBill
I sometimes use sealer/adhesive to hold the rubber onto the glass, but not on the window opening......it may be possible, but every time I've tried it just makes a huge mess. If the rubber fits the opening right, you should not need sealer.
EDIT Wayne: Yes, small pieces of glass are much harder to install. Plus I think it might have been cut a shade too big.
  #358
Old 09-16-2014, 02:24 PM
tractormanbill
tractorman
That is what I was thinking.
I was in the VW business for many years and we used silicone spray or soap suds and put a ton of them in without any sealer and no leaks.
Thanks,
TractormanBill
  #359
Old 09-17-2014, 12:01 PM
underthebridgejim's Avatar
underthebridgejim
underthebridgejim is offline
FTE fan
Looks nice with the glass in.
  #360
Old 09-21-2014, 08:35 AM
petemcl's Avatar
petemcl
petemcl is offline
Still Learnin'
Originally Posted by tinman52
The tank is from a '52 panel, luckily I saved the mounting brackets, was basically a bolt in deal. After I moved the filler pipe and pickup tube.
That is an interesting solution to the gas tank relocation issue.
Quick Reply: Tinman's '51 Cabover lowbuck build
