Tinman's '51 Cabover lowbuck build
#602
#603
#604
Hey Scott,
The shakedown phase can be pretty frustrating. Our engine chewed up the pushrods at under 1,000 miles -
the builder didn't use case hardened rods grrr.. I feel your pain - hang in there.
We sprayed our cab interior with a bedliner type product called Toff. It's a nice low maintenance solution -
we used it everywhere except the dash. Pick up a couple of rubber floor mats & you are good to go. Does it get warm
in the cab? We open up the cowl & the windows - not too bad - but it's always hot here in Texas.
Good luck over there - keep up the momentum!
Ben in Austin
1950 F1
Ben in Austin
1950 F1
#605
#606
#607
#608
The cam is an old NOS sealed power unit.....I think 204/214 duration 450/475 lift.
I got the engine all assembled and today got it put back into the truck. It was a tight fit, had to leave the manifolds and one motor mount off to get it in.
Will work on getting everything hooked up and hopefully fired up this week....
#609
Received 4,130 Likes
on
#610
I hooked up the radiator temporary and fired it up the other day. The engine runs nice and no noises. I had a minor oil leak(side cover) so I figured I better fix that before going any farther. Then I sprained my ankle, so not much else got done.....................
Will get the fenders etc back on in the next few days.
Sorry, no pics.
Sorry, no pics.
#611
#612
It is a GM pump, but an older one. It seems to work fine. I had to modify the Ford pump bracket to make it fit.
#614
#615
Good progress Scott
Haven't peeked in in a while. lots of progress and the truck is lookin awesome.
Tastefully done.
I've been busy firing up my 59 Beetle after motor rebuild. Hope to go for a spin before snow comes.
Been driving my F1. hauled leaves and branches to recyle today. then went for a two hour cruise.
Keep at it, hope to cruise down your way next summer.
Tom
Tastefully done.
Tom
