Just got my '49 F4
Just got my '49 F4
I'm stoked! It's in amazing shape.... Looks like it just needs an engine rebuild and it can hit the road!
I was considering putting a newer diesel in the truck.. Any suggestions? It currently has the flat 6... So far it looks ok(not cracked). I want to use this truck as. Daily driver and don't mind a bit of customizing done to it..
Thanks in advance... And it seems I'll be spending. Lot of time on here.
Guess I need to read up on how to post a photo here.
D
D
D
D
The flat 226 six is said to be a strong engine in these trucks. As much or more torque than the V8, and bullet proof. If it was me I'd rebuild it and call it done. But putting in a diesel has been done. One of our members used a Benz engine, IIRC, in a 53-56 era truck. I'm coming up dry on the member's user name.
Wheels - maybe you've already read all that's been said about the wheels on the F-4/5/6s, but if not you'll want to do a Google search about them. I don't think you have enough postings to use the FTE search function. The 18" and 20" wheels supplied on these trucks have an outer rim design that has a trade name "Firestone RH-5°". Today the common name for them is "widow maker". You'll want to find replacements, especially if you intend to use the truck as a daily driver. Good replacement options do exist. Stu
I'll add my welcome to the forum. You've come to the right place for answers and suggestions. Lots of knowledgeable folks on here (present company excluded) who are always willing to help. I look forward to seeing pics.
On the 1948 - 1956 F1, F100 & Larger F-Series Trucks forum home page, go to Read First: 48/60 Forum Tips, Tricks, How To's! and select HOW TO POST PICTURES
Welcome! Great to hear about you being the caretaker of an F-4. I have a 48 F-3 with the same engine.
What part of the country are you from? You might put that in your profile as fellow FTE members in your area might be able to help out or provide a part or two.
I'll add my request for pics. Would like to see what your truck looks like.
Rob
Rob
I'll second the term *BULLETPROOF* when it comes to the 226! From the factory they are rated at having 5hp less than the same year V8 if I remember right, and definitely more torque. They are a spunky little torqey motor - full of **** and vinegar.
I love mine - it will never sound like a V8, so if you want that load roar you are outta luck there, but a nice purr and growl they got.
My advice - DRIVE IT, do not tear it apart. This forum is littered with dozen of guys 80% of the way through a frame off rebuild who will take years to get it back together. Ask all you want, and if you have 226 questions feel free to ask me cause I drive one all the time - took it to work today. I myself spent 8 years without it and I regret every day of it. Start enjoying your truck now - you can always buy a fender, get it straightened up, shoot it and then swap on a weekend... tearing it down to the frame and you will have lots of "life issues" get in the way that just eat up your will.
Macs Antique Auto, Classic Haulers, Obsolete Ford Parts, Sacramento Ford, there are dozens of dozens of places that sell parts. I believe Macs has a free shipping right now on $150 or higher orders (coupon code FREEDEC) now through the 20th (be sure to order before 8p eastern cause their computer shuts the sale off long before midnight) and I am pretty sure Macs has a 226 gasket kit, and some rebuild stuff... if it don't smoke like he** then don't tear it down - drive it.
Be pretty careful changing out the ratios, you can overdo it and end up where I am (hunting for a tranny swap now after doing a rear end swap). The 57-72 Ford F series truck 9" is a direct swap in the F1, I suggest getting the newer self adjusting brake style. BUT - pay more attention to the ratios you get (I screwed up and got a 3.00 with a crash box - learn from my mistake)... You want at least 10.5:1 1st gear ratio to keep clutch abuse down. A lot of guys go with the 3.50 and if I had it to do over again that is exactly where I would be to stick with the crash box.
What transmission do you have? - all the gear ratios can be found here (as well as my stolen pictures of mtflat's adventures.
https://www.ford-trucks.com/forums/1...-progress.html
(post #5)
(post #5)
If you go with an overdrive transmission you'll improve road speed. Finding one of the o/d 5 speeds that were available on the bigger trucks might be a task. Short of that, since we're talking about an F-4, changing axle final drive ratios isn't a simple matter. The F-4's split case Timken axle had 5.14/1 or 5.83/1 optional ratios. Like all the bigger models it has the 5 lug x 8" pattern hubs that need to be retained to maintain a match with the front hubs. No taller replacement ring/pinion sets have been found for them to my understanding.
If driving highway speeds is needed you'll find yourself looking at replacement rear axle options. The most commonly discussed option is the rear axle from a '70s era Dodge/Ford based motor home. Not sure if they are Eaton or Dana 70 axles, I've read of them described both ways. This would yield a final drive ratio probably in the 4.56/1 range which, when teamed with the 8R19.5" tires, would work for highway travel. After all, this worked for the old motor homes. Possible down sides here would be a wider rear track than the stock Timken, and need to deal with the parking brake at the wheels rather than at the transmission. Stu
