Shock!
Shock!
OK, I have not seen any type of thread regarding this. After driving to your next destination, shutting off the truck, and upon opening the door, you get a pretty nice static shock when you open the door. It will startle this crap out of you. How many of you have had this happen and is there something we can do to eliminate this static shock? Mine gets real bad when the hot and dry Santa Ana winds blow.
on
Lol, Rick. Believe it or not, that little zap is your friend. Cars build up a lot of static electricity when just driving down the road. It's the tires. Think about rubbing a baloon in your hair and what happens? Static electricity builds up and you can walk over to someone and zap them. A car's tires are constantly rubbing on the road and building a charge over the surface of the car. When you enter that field with your hand on that little metal strip in the door handle, you complete a circuit and discharge the electricity into your hand. This makes sure that when you're filling up your GAS tank, you don't spark and ignite the GAS fumes. It's not necessary for diesel vehicles because a spark will not ignite diesel but it is useful for that guy you walk up to that's filling his gas tank.
Google GAS PUMP FIRE STATIC and watch a video of what happens when people don't ground out before pumping gas.
I know exactly what you mean and Epic is right on. I've seen some people use a ground strap. It's a flat rubber strap that hangs down from the frame in the rear of the vehicle and it's long enough to touch (drag) the ground. Here's a website for them Antistatic strap for cars - STOP static shocks! Stop Static Electricity in your vehicle!. I don't like them personally, but it probably beats getting shocked.
Good luck.
Good luck.
I'm here in AZ where it is usually pretty dry. I have the King Ranch with the Saddle Leather. I will occasionally get the static shock getting into the truck.
MythBusters did a whole episode on the Static discharge/fuel ignition (mostly with the cell phone theory). It seems it took a whole lot of manipulation to get it to ignite. Enclosures to get the vapors to be high enough. Larger current for the electrical discharge, etc etc. so IIRC mostly busted the myth.
I have never had the problem with leather seats; but, with cloth seats I have. Putting some fabric softener in a spray bottle and lightly misting the seats would take care of issue; maybe try same with your carpet.
Learned this trick years ago watching a video by the original inventor of the pink anti-static material for electronics.
Bob
Bob
AJHEATING
30
05-13-2011 10:22 PM
nflfreak43
63
09-28-2008 04:38 AM
