460? - Ford Truck Enthusiasts Forums
460?
Old 04-16-2003, 12:12 AM
DySpokane DySpokane is offline
DySpokane is starting off with a positive reputation.
Question 460?
I just bought a 1979 F-150. The engine is a 460. My question is- Could this be the original engine and if so what is the correct timing?
Old 04-16-2003, 12:28 AM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
460?
Welcome to FTE!
This is NOT a 73-79 specific question,it is a 460 engine question.
You may either check in the 385 engine series forum or go to my web site and get the info right away.
Do you see my sticky post near the top of this forum?
It says : Tune-up specs.
Go here >
http://www.clubfte.com/users/mil1ion...e-upSpecs.html
Look up your Truck model with engine >
Write down the calibration code .
I think it is 8-97-R0 for Non-California 460's
Scroll down the page until you find this number [8-97-R0].
I think it is near the bottom of the page>
Read across the tune-up specs
If I remember correctly it is about 12* BTC .
Make sure you read the other parts too.
Old 04-16-2003, 11:14 PM
460?
Gee I'm SORRY. Next time i'll pay more attention to the subject of my question and catagorize it accordingly. thank you for your help. The spec. sheet was helpful.
Old 04-16-2003, 11:37 PM
masterbeavis's Avatar
masterbeavis masterbeavis is offline
masterbeavis has a very good reputation on FTE.masterbeavis has a very good reputation on FTE.masterbeavis has a very good reputation on FTE.
460?
Here's a devils advocate question for you. If you stumble across a motor that you have no idea as to what it origionally came out of (for instance a '73 4WD with a 460, and it has had a backyard rebuild done to it (a can of spray paint) How do you tell where to set the timing then?? It could be anywhere from 6* to 16*??!?!?
Old 04-17-2003, 12:32 AM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
460?
Try a middle of the road setting and if it pings drop it back a couple of degrees, if it doesn't ping set it forward a couple until you find a setting it likes.
Old 04-17-2003, 08:00 PM
mk's Avatar
mk mk is offline
mk is starting off with a positive reputation.
460?
I'm afraid I can't see what isn't 79 specific about that question. The gent wanted to know if that engine was original for his 1979 Ford Pickup
Old 04-17-2003, 08:44 PM
Seabeetough Seabeetough is offline
Seabeetough is starting off with a positive reputation.
460?
Im alittle confussed about this 73-79 specific thing..... If i dont know what the engine came out of but it is in a 73-79, wouldnt that kind of make it a question for the 73-79 forum... ? Ive seen this a few times. Yes if the question was just about the 460 then it isnt a specific questiond but if it is about a 460 thats in the right type of vehicle would that make it a specific question for both forums? Im just wondering about this because it has happened to me also.
Just a thought..
Old 04-17-2003, 10:09 PM
460?
It was a long night.
I originally took it as a *460 Identification* question.
The fact that I suggested to him to look at my 77-78-79 Engine specs meant it is possible & if it is actually a 460 *there are the specs for it*.
All my little bit of info mentioned to him >>>were 460 related.
Old 04-17-2003, 10:45 PM
Torque1st's Avatar
Posting Legend
460?
Admins and Mods are semi-human (part trolls) and are fallible. We suffer from brain farts and memory lapses just like most people.
Old 05-08-2003, 11:34 PM
Colossus Colossus is offline
Colossus is starting off with a positive reputation.
460?
One way that I've heard of checking to see if a 460 is original is to see if it is 4-wheel drive. To my knowledge, the 4-wheel drive trucks did not come factory with a 460. I was recently looking at a 79 F150 4-by-4 with a 460 in it, just from that I knew it wasn't original, and I was right. Regardless, it sounds like a good buy, but check it over real close to see who installed the engine, and look for reciepts so you know what went into it - to see if its a new engine or a jury-rigged rebuild.
460 engine siezed?? Pastmaster 1987 - 1996 F150 & Larger F-Series Trucks 13 06-24-2011 10:20 AM
more power out of 460 engine Willie 1973 - 1979 F-100 & Larger F-Series Trucks 11 05-13-2011 01:06 AM
Horse Power #'s for a 69 Lincoln 460 engine merc460 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 5 07-17-2002 03:10 AM
460 passenger car or 460 truck engine any differences? 78bigunns 1973 - 1979 F-100 & Larger F-Series Trucks 5 06-03-2002 01:16 AM
mustangII suspension w/460engine darkhorse54 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 06-01-2002 04:22 PM
Tags
1979, 460, 897, calibration, ford, specs, tune, tuneup, tuning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
