Electric Fan cooling down my 77?
Ok I was just reading an article about installing an electric fan (not aftermarket) in an older mustang with a 302, the results are here~
http://www.fordmuscle.com/archives/2...an/index.shtml
I was wondering if I could do the same on my 77 302 in my truck? I want to do this because heat kills engines and heat also sucks more gas.... The article says that there was a gain of 1-2mpg on the freeway and it keeps the engine much cooler. Also it is not one of thoes expensive aftermarket fans. It is a fan out of a 3.8 V6 Ford Taurus it pulls aprox 2000cfm of air. Parts and cost are:
Fan 3.8L Taurus $25
Imperial Controller PN: 3647 $36
Imperial Mount Kit PN: 226201 $6
Bosch 150amp Relay PN: 0 332 002 156 $30
Free-wheeling Diode PN: 1N5408 $5
but I was not sure what all I would need for the job since I have a 77... Would anyone have any ideas?
I was thinking that maybe somone made somthing like a temp. switch, something when it gets hot it turns on and when cools down it turns off?
Also, Would my alternator be able to handle that size fan?
Are there other alternatives to a cooler engine (besides a bigger radiator) because I already have an over-sized radiator...
Fan 3.8L Taurus $25
Do you have an over heating problem? Your engine should be running about 190-210 deg.
If the fan cools a built 302 in a car, it should cool your stock 302. Do you do much towing, stop and go traffic? These will require more cooling.
As far as the electric draw, find out how much the fan takes, then you will have to get that much bigger of an alternator.
It might be better to get a clutch fan. Less drag on the engine and doesn't use electricity. Plus they can be found on '73-'79 pickups...
Marty
Marty
No over heating problems.... Dont tow anything and I havent recently been stuck in traffic.... Clutch fans also cause drag on the engine and dont cool as well as the electric fan, plus I would get a little better mileage out of an electric fan...... And I like the look of just pullys... and wont haveto worry about geting my finger choped off when I am working under the hood.....
Electrical fans cause drag on the engine also, they just apply it thru the ineficiencies of the alternator. You won't notice any milage differences. They don't cool any better than a clutch fan. Turn your engine off and you won't need to worry about the fan chopping your fingers. Depending on how they are wired an electric fan CAN start suddenly and chop fingers. Heat actually helps engines which is why OEM's keep going to higher temp thermostats as material changes allow it. Electric fans came into favor to cool itty bitty sidewinder engines. They have some advantages if a computer controls them.
If electric fans arent all that great, the why do most or all new trucks and cars have them? Did you read the link I posted? There was a 1-2 mpg gain.... Also I know I would need to upgrade my alternator, then there would be enough current flowing so there is no drag.... And I am not fixing somthing that is not broken, I am makeing it better...... Just like if you were to upgrade your carb... ir ignition... or upgrade small parts on your engine... Also... I thought that radiant heat kills engines, the fan helps keep radiant heat in the engine compartment to a lower temp so it does not damage the engine? I thought I would atleast get a little suport for this project... but I guess you disagree with it? I duno... If I have the extra cash at hand why not? I meen I cant think of anything else to spend it on? Unless somone has a beter idea?
Sidewinders have to have them, There are benefits when the fan is controlled by the engine management computer, but not by just a temp switch.
Sorry but the 1-2mpg gain was probably closely related to the type of wishfull thinking that occurs when a tornado unit or magnets on the fuel line are installed.
Did you not take Physics??? It takes POWER to produce electric current to run the fan. Power that must come from the engine, that is converted from rotary motion transmitted thru a slipping drive belt, to a marginally efficient alternator, then converted to DC thru diodes, then transmitted by imperfect wires, thru switch contacts, to another marginally efficient motor, where it is turned back into rotary motion. Sounds like a complicated process compared to the mech fan.
Actually you will be making things more complicated and not any better...
Upgrade when it makes sense. This doesn't
Radiant heat kills engines... Where does this come from? Again did you sleep thru Physics class? A fan will help lower engine compartment air temps but then the clutch fan is probably better for this than the electric.
Get your basic engine running right b4 you attempt any modifications.
Bowtie_Schmowtie
17
08-21-2009 05:17 PM
maxoverdrive69
03-21-2007 09:55 PM
