Low boost?
Well, that doesn't mean much. Batteries were disconnected at some point basically...
Do you hear a loud air whoosh type of noise at idle? The up pipes are good for getting holes in them at the flex sections. But if your really only getting 12 PSI at max, you should have a code. Where did you tap in for the boost gauge?
IDK if your last post means that you got it working right or not
But I think somethings wrong with either the gauge or the install
Because both Boost and EGT numbers were way off
200* EGT is not right no matter what well maybe if you just shut truck off but running NO WAY 200* EGT
12 Psi Boost at WOT is not right unless you are having drivability issues along with it
But at WOT should be like 24-28 psi Boost
derek0525
13
01-19-2016 03:57 PM
UP_There
12-04-2008 06:10 PM
