No smoke when cranking/No start unless plugged in.
Old 11-11-2011, 03:10 PM
JamesHajek's Avatar
JamesHajek
JamesHajek is offline
Just as the title says. The new truck doesn't want to start without being plugged in. Cranks over fine. Has new batteries. Fuel in the fuel bowl. HPOP res is full. GPR is working. I haven't tested the glowplugs but I am concerned that might not be the problem since there is no smoke out of the tailpipe when cranking. The previous owner told me it was glow plugs but I'm just not so sure. I've had bad glow plugs on the OBS and it always smoked while cranking and after starting rough. This truck just cranks but no smoke, no nothing unless you plug it in.
With the HPOP res full and fuel bowl full, what should i be looking towards? Injectors? IPR? I don't have a scanner yet... working on getting AE. Could it be a compression issue? The truck has more blowby than my OBS but isn't enough to blow the oil filler cap off. Truck has 144k miles.
I guess I would like to know where you guys would start searching for the problem...
Old 11-11-2011, 03:25 PM
Brother Les's Avatar
Brother Les
Brother Les is offline
https://www.ford-trucks.com/forums/1...ky-thread.html
https://www.ford-trucks.com/forums/1...d-you-did.html
Old 11-11-2011, 07:28 PM
F350-6's Avatar
F350-6
F350-6 is offline
If plugging the truck in makes it start every time, then I would be pulling the valve covers and watching for oil discharge from the injectors. ICP and IPR shouldn't be affected by plugging the truck in, but worn injectors will work better when the oil is warmed up.
And for trouble shooting this, the method is exactly the same as on the OBS. The SD doesn't have any parts that would change how the truck did or didn't start.
Old 11-11-2011, 09:24 PM
JamesHajek's Avatar
JamesHajek
Plugging in the truck makes it start. It still cranks for a couple seconds. I guess ill get the vc's off and run it to see what the injectors are doing.
Old 11-12-2011, 05:48 AM
PwerStroke99's Avatar
PwerStroke99
PwerStroke99 is offline
James, have u serviced that engine yet?
Old 11-12-2011, 09:07 AM
JamesHajek's Avatar
JamesHajek
Not yet. It's been parked since I bought it. lol.
Old 11-23-2011, 12:26 PM
JamesHajek's Avatar
JamesHajek
Chris, I finally have time to work on the truck. Once the valve covers are off and I get to watching the oil spouts, should I have the truck plugged in beforehand or no? Do I want the truck running or just cranking on it?
Old 11-23-2011, 06:23 PM
F350-6's Avatar
F350-6
F350-6 is offline
No, don't plug it in at first. Watch the oil discharge while someone cranks the engine. See how many injectors you have not spitting oil. If it starts up, let it run and warm up. As the engine heats up, you'll see the oil start flowing better and start coming out of the injectors that were not spitting oil cold.
Then if you want, let it cool down and then plug it in for a couple of hours to see what difference the block heater makes in terms of how much or how many injectors are spitting oil.
Old 12-05-2011, 10:40 AM
JamesHajek's Avatar
JamesHajek
Ok guys, new twist...
I took off the intercooler pipes, intake, and vc's. Had a friend crank on it after sitting for about two weeks and no plug in. I was looking for oil coming out the injector spouts and it started right up. Smoked like a pig ran for about 1 1/2 minutes. All the injectors spit oil. Then I went to shut it off but it died as I reached for the key. With all the injectors spitting oil, I'm not sure that is my problem anymore, not sure why it started first crank... Not sure why it died...
Any ideas?
Old 12-05-2011, 11:16 AM
kawcrasher's Avatar
kawcrasher
kawcrasher is offline
A minute and half would be right about when the GP's shut off. Could it be so low on compression it will only run on a warm motor or the GP's on? Try jumping the relay and see if it runs then.
A second thought, Could a bad temp sensor not let it know it is cold enough to turn on the gp's unless it is real cold then let it think it is warm after a few seconds and allow the pcm to treat it like a warm engine and cause it to stall? I don't know what is changed for warn/cold running, but I'm sure electronic engines change some parameters.
Old 12-05-2011, 11:34 AM
JamesHajek's Avatar
JamesHajek
It has a new Stancor GPR on it... I ohmed the glow plugs and only had two bad ones...
I have not checked compression yet, but that is on the list of things to do.
Old 12-05-2011, 11:52 AM
kawcrasher's Avatar
kawcrasher
It seems to have quit right when the gp's go off, try manually jumping the relay and see if it runs until you pull the jumper than dies again. That would show if it only runs as along as the gp's stay on or something else caused it to die around the same time.
Old 12-05-2011, 12:57 PM
JamesHajek's Avatar
JamesHajek
I got it to start again just now but it ran super rough and died after about 25 seconds this time.
http://www.youtube.com/watch?v=Bz1zQ8YmonI
Sorry about pointing the camera into the sun... At the end, I was trying to keep it alive and the throttle wasn't responding very well and it died...
Old 12-05-2011, 01:47 PM
JamesHajek's Avatar
JamesHajek
Also, it will not start with the ICP sensor unplugged..
Old 12-05-2011, 02:00 PM
tdpower's Avatar
tdpower
tdpower is offline
Does it sound like this you tube video with a broken injector tip: greysmoke.MOV - YouTube
Quick Reply: No smoke when cranking/No start unless plugged in.
