Custom headache rack - paint/coating recommendations?
My brother-in-law just finished building me a custom rack for my 75 f250. As it is now, it is unpainted - raw steel. I will need to paint it or apply some sort of coating on it to protect it from rust.
Some things I have considered:
-Rustoleum Hammered - would brush on - not sure about durability.
-Al's DIY bed liner - Used it before putting my drop in bed liner - seems durable - a bit pricey.
-PlastiDip - would seal nicely - but likely tear easy too?
-Rustoleum textured spray paint - durability?
-Line-x or Rhino Liner - Ideal but likely going to be expensive.
-Professional powder coating - not sure about durability.
Any recommendations on this?
Here is a shot of the rack resting in place (it actually moves about 6" closer to the back of the cab where it will be bolted to the rails.)
powder coat or line x it. everything else you mentioned will just end up failing in the long run and youll be repainting it again. I had my bumper line x'd about 5 years ago and it still looks great and I dont have to worry about rust or chipping paint. It cost $160 but its worth paying the extra money and doing it right with quality stuff.
You could use a two-part epoxy primer. 2 coats will protect it from any rust, and dry to a black satin type finish. I get mine from this manufacturer; http://www.southernpolyurethanes.com/
You could use a two-part epoxy primer. 2 coats will protect it from any rust, and dry to a black satin type finish. I get mine from this manufacturer; Home
If you prime it with epoxy primer it should be top coated, especially if its in sunlight like your rack. Ive never used SPI paint but, from my experience epoxy primers are not UV resistant and should be top coated.
I didnt know that Barry mixed his epoxies to be more UV resistant. I ve been wanting to use their stuff for a while mainly because they sell it for such a good price. Ive heard a lot of good about their clear too, have you ever used it? I actually want to use their primers and clear when I paint my truck.
https://www.ford-trucks.com/forums/9...build-log.html
Home
SPI User Forums
POR15 is supposed to be really good. UV's degrade it though, so you'd have to topcoat it.
POR15, Inc. - Stop Rust Permanently - Repair Gas & Fuel Tanks
But it doesn't look like rusty metal. It looks like a fresh build that needs to be protected from rusting.
I just recently started doing the body work on my truck (as in this year). I am using all SPI primers right now. In the future I will probably be using their bed-liner. I am also going to check into their black base-coat, and their clear. I have never done anything like this before, so I am not sure if I will be doing the painting myself or taking it to a body shop. I have been teaching myself how to do the body work and spraying the primer. I am on the SPI forum also, and like this forum it is full of very knowledgeable people. Here are a few links to my project/build, and the SPI website, and forum.
Home
SPI User Forums
Home
SPI User Forums
jerry73
23
05-07-2016 09:24 PM
GNR22
24
05-04-2012 12:19 PM
