Heater Blower Cold Problem
When it's cold outside (below 45) the blower motor will not turn on in heat or A/C mode but as soon as it warms up enough to check it the dam thing works. So I will need to diagnose it while it's cold. Anybody ever had or heard of this problem or any ideas on where to start looking?
Engine Temp doesn't seem to affect it. The engine warms up by time I get to work but the fan still doesn't come on but it works everytime when I go home in the afternoon.
If the resistor is cracked, temperature could cause warping that could open the circuit or close it. Pull the blower resistor, and ohm each of the circuits (three or more plugs, common ground) when in is cold. Also look for cracks in the stabilizing structure on the coils.
This is the only thing I could guess.
mechelement
11-10-2010 07:01 PM
Big Red
01-18-2007 12:11 PM
