Anybody install cablights on a truck with satellite radio?
Recon Clearance Lights Installed...w/ lots of Pics....56k Warning - Ford Truck Enthusiasts Forums
follow this thread. i believe there are pics of someone with the sat. ant.
If you have a moon roof then what you would need to do is adjust the lights inward for the outer two. If you have no moon roof then just slide them back more and there will be no issues. I dropped my headliner first so that I could see everything in the areas before I started to drill into my roof but Tylus just drilled in and then dropped the liner. Both work but with the radio I recommend dropping the liner first.
