Transmission Gear Reading ScanGauge
ScanGauge X-Gauge:
Transmission Gear = GER
TXD: 07E12211B3
RXF: 0462051106B3
RXD: 3008
MTH: 000100020000
The low gears had numbers corresponding to the gear 3,2,and 1.
When shifting through Park, Reverse, Neutral, and Drive, all of these gear positions displayed a 1 on the ScanGauge. What should the GER X-Gauge readings be?
Thanks.
TXD: 07E12211B3
RXF: 0462051106B3
RXD: 3008
MTH: 000100020000
Thanks.
It worked these are the values I came up with when I moved the gear selector
transmission range sensor values
park=140
reverse=120
neutral=100
drive=92 and remained the same threwout the driving range 12356
3rd= 46
2nd=44
1st=42
Do you guys come up with the same readings
thanks again amdriven2liv
park=140
reverse=120
neutral=100
3rd= 46
2nd=44
1st=42
to start you HAVE to be in
park=140
neutral=100
this is what it reads there should have been a decimal point in there like 1.40 or 1.00volt EVERY sensor should fall into the 5 volt referance range but oh well I dont know if they ever fixed it the X-code that is so you will see the value in the quote Better than nothing
Thought I had the x-code to hang on
Sycostang67
08-04-2006 07:01 PM
