You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Hello, I'm looking for the engine perches from a 1980-1982 F-Series truck or Bronco with a factory 351M or 400. If you have a set, please let me know. Thanks!
__________________
Shaun
-1980 Ford F150 4x4 Ranger Lariat -6.6 400 V8/C6/NP208/D44/Ford 9.
-2003 Ford Ranger Edge+
-3.0 V6/5R55E/Ford 8.8
E0TZ-6028-A Right & E0TZ-6029-A Left .. 351M/400 Engine Supports / 2WD/4WD same / Obsolete
Applications: 1980/82 F150/350 & Bronco.
No Ford Dealer or obsolete parts vendor has any.
Largest available engine in 1980/83 F100: 302.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
Thanks for the reply Bill.
As for the last part of your response, my truck is originally an F100, however I have swapped a D44 TTB front axle into it, which with new front coil springs will bring the GVWR higher than the 5150 GVWR the truck originally had. Since the suspension of the truck is no longer true, and since she's already a Ranger Lariat clone, I've decided to go ahead with the F150 clone as well. The 351M was an option in the F150, and some rare cases of F150 also featured a 400. I want this truck to be something that could have easily been ordered on the assembly line, but completely unique at the same time.
__________________
Shaun
Unfortunately those look to be from a 68-79 truck, and they will not fit my truck. The perches were re-designed in 1980, so I need a set from a 1980-1982.
Thanks anyway!
__________________
Shaun
