How-To install cab lights - Page 2 - Ford Truck Enthusiasts Forums
Old 04-18-2012, 05:04 AM
ncranchero's Avatar
ncranchero ncranchero is offline
ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.
Quote:
Originally Posted by frederic View Post
I had originally replaced the outer two sockets with two-wire sockets and installed dual-filament bulbs so they'd light up with the others but also act as turn signals. That got annoying at night reflecting on the hood so I installed the original sockets back in and wired accordingly. I use a switch in the Chrysler overhead console I installed to operate them separately from the parking lights and the center console taps power from the mounting flange of the original, mostly useless interior light that the console covers.
Hey Frederic, have a comment and question. I'm going to do an install of the lights and had also planned on doing the turn signal flash as you initially did. So you got enough reflection on the hood that you went back original non-flash? I hadn't thought of that. What Chrysler overhead console is that you're using? It may be too long for my regular cab but I thought I'd find one and measure it and see, unless you'd give me the length on yours. May be better if I just add a short Explorer console.
Old 02-09-2014, 05:32 PM
Kouwenberg7.3 Kouwenberg7.3 is offline
Kouwenberg7.3 is starting off with a positive reputation.
looks pretty good
Old 02-09-2014, 05:35 PM
Anyone know where i can get the male end of the plug (my kit doesn't include it) or what the part number is?
Old 02-09-2014, 07:27 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Quote:
Just get some bullet connectors and put them on your harness. Then it will plug into your stock harness. OR get a cab light harness from a 92-97 truck
Old 02-10-2014, 02:37 AM
Vadis's Avatar
Vadis Vadis is online now
Vadis is starting off with a positive reputation.
Thanks for the write up Brad.
I'm on the fence about adding them to my truck but at least I know how to do it if I do go for it.
Old 02-10-2014, 04:07 PM
mrrish79's Avatar
mrrish79 mrrish79 is offline
mrrish79 is starting off with a positive reputation.
Great write up, I should send it to the PO of my truck as he hacked up my truck to install the cheapo ones that take in water and blow bulbs all the time. I would change them out but don't want more holes in my roof.
Old 03-08-2014, 12:58 PM
Island'r's Avatar
Island'r Island'r is offline
Island'r is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Diesel_Brad View Post
Actually, I just fond them for $4.88 a piece! Think I'm gonna order me up some NEW shiny lens'
I know this post is as old as the hills... but just wondering if you did order those lights for that price and if so, were they the real deal?
I've got a line on a used harness, but thinking I might buy a full set of new lights... No way I'm paying 50 bucks a light from ford though, and no one else seems to carry Truck-Lite around here...
Old 03-08-2014, 01:17 PM
Vadis's Avatar
Old 03-08-2014, 10:54 PM
Island'r's Avatar
Yep, those are the ones I'm talking about. Went ahead and ordered a set, but just realized that it doesn't say whether they come with gaskets or not...
Anyone know if they do?
Old 03-09-2014, 03:22 AM
Evan_P's Avatar
Evan_P Evan_P is offline
Evan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to behold
I talked with Brad about that a few weeks ago. They do include new gaskets that are bonded with the lights.
Old 03-09-2014, 09:51 PM
Island'r's Avatar
Quote:
Excellent! Thanks!
Old 03-09-2014, 10:14 PM
BiGGreen350's Avatar
BiGGreen350 BiGGreen350 is offline
BiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant future
used the ford lights on my 97, paid almost 140 bucks for set of five even with my discount.
then once brad told me about the ryder ones we used them for the 84 build, bought a nos harness and pigtails from ford.
needless to say the ryder ones are the exact same, in quality and appearance.
  #28
Old 03-09-2014, 10:55 PM
Island'r's Avatar
Both look great!!!
  #29
Old 03-10-2014, 12:11 PM
460jared96's Avatar
460jared96 460jared96 is offline
460jared96 is starting off with a positive reputation.
I just installed mine this past weekend and they look great! thanks for the plans Brad. And ya, drilling the first hole is definenatly the scariest thing. I installed mine in such a way that to turn them on you pull the light lever half way out for the front running lights, and then you flip a switch that installed beside my overdrive button. very impressed with the look.
  #30
Old 03-11-2014, 01:47 AM
Knewstroke97 Knewstroke97 is offline
Knewstroke97 is starting off with a positive reputation.
BIGGreen350, what were the part numbers and the sources for the Nos wiring harness and pig tail harnesses? Looking to piece this job together.
My CCSB build Diesel_Brad 1987 - 1996 F150 & Larger F-Series Trucks 274 04-13-2016 09:05 PM
Precision Metal Fab RSK Diesel_Brad 1987 - 1996 F150 & Larger F-Series Trucks 86 10-05-2015 10:07 AM
My 97 SCSB Build Diesel_Brad 1987 - 1996 F150 & Larger F-Series Trucks 33 09-24-2015 06:21 PM
Class V hitch Diesel_Brad 1987 - 1996 F150 & Larger F-Series Trucks 17 03-30-2015 11:37 AM
Flairside pic request Diesel_Brad 1987 - 1996 F150 & Larger F-Series Trucks 30 04-09-2011 09:19 AM
Tags
2011, bronco, cab, dity, drill, f150, f250, f350, ford, install, light, lights, plug, ranger, truck, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
