P0354 code on 2005 Escape - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 12-13-2011, 12:41 PM
firemech firemech is offline
firemech is starting off with a positive reputation.
So it all started 3 weeks ago. Drove the ol' 2005 escape with my wife to dinner. All was running great. Got a call from my wife the next morning and said it is running rough. Run back home and took the reader with me, found active code P0354. So did some research, found that it could be either the spark plug, wiring, coil or the PCM. So I transferred the coil, still had the same problem with the same cylinder #4.
Checked the wiring from the PCM to the coil all OK. Next check was to see what spark plugs were installed, found the original ones and the wrong ones as per the Ford service bulletin. So I installed the new correct spark plugs, put on all new Ford OEM coils since I had the intake off anyway, did that, still had the same miss on the same cylinder. So I ended up taking it to the dealership. I received a call back and the PCM failed, but all of it was covered under warranty. I was also able to get my coils covered since I used OEM Ford ones. So it is nice to see that there are still some good people out there and willing to work with you.
Old 12-14-2011, 09:52 AM
wptski wptski is offline
wptski is starting off with a positive reputation.
Do you have an extended warranty plan?
Old 12-15-2011, 09:29 AM
No according to Ford the 05-06 Escapes with a P0350-P0356 codes are covered until 8 yrs/80000 miles under the emissions warranty, if the PCM failed. There are numerous web-links that cover this. I would never known if I didn't Google 2005 escape with P0354 code. It is only a tech bulletin but it helps to know up front and also lets the dealership know you have done your research.
Old 12-15-2011, 09:58 AM
Quote:
I know about the TSB and yes there are many posts about the problem but many have paid to get it fixed. Your the first that I've read about getting it fixed under warranty. Also because of PCM programing or lack of, continued driving will destroy your CATS also.
Old 12-15-2011, 10:25 AM
I also read about the plugged cats if you drive it, so I hauled it to the ford dealer. I didn't have any issues to getting it covered. But I also had my guns loaded with all of the info ahead of time but didn't have to use it.
help 2005 escape code o354!!!!!help bodyman36 Escape & Escape Hybrid 2 11-04-2015 08:29 AM
Vibration between 40-55MPH RTrud Excursion - King of SUVs 17 07-13-2015 07:37 PM
help 2005 escape code o354!!!!!help bodyman36 Escape & Escape Hybrid 1 04-17-2013 07:39 AM
P0354 Code What next eswatcher86 1997 - 2003 F150 5 02-19-2013 01:57 PM
ignition coil circut malfunctions to cylinder #4. bad spark plug? Twistedking 2004 - 2008 F150 0 11-28-2012 08:42 PM
Tags
06, 2003, 2005, 30l, 46, 60, code, coil, escape, f150, ford, p0354, plug, po354, vortec
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
