Dual exhaust
Dual exhaust
hello i have a 1981 F150 ranger stepside with the factory 302. It had dual exhaust running to the back but my question is; Can i run the dual exhaust on both driver and passenger side at all? i don't like the look of the dual running down the same side then to separate sides. If you can help please contact me. Thank you
(gas tank runs on the driver side under the bed.)
There is really not much room between the driveshaft and the fuel tank. I wanted dual exhaust, so I moved the fuel tank to behind the axle and between the frame rails. Of course, I had to lose the spare tire. But now I have lots of room to run dual exhaust.
Good luck with your project, and welcome to FTE.
Ron
Ron
Ron
Ron
If you do decide to run the exhaust outside the drivers frame rail inspect the side tank and replace if need be. My tank leaks a bit at the top seam when its over half full which i've found to be pretty common with this era of F series.
I went with a nice single exhaust, the other options were a cat back dual system which i thought was kind of a waste of money or full duals for twice as much.
Walk around of my 1985 Ford F-250 HD - YouTube
Here's how it is ran on my truck. Skip to around the 3 minute mark.
STANGIN
12-10-2004 01:41 PM
kermit
02-11-2004 02:34 AM
