Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 12-13-2011, 09:50 AM
bashby's Avatar
bashby bashby is offline
1992 Ford F-250
bashby has a very good reputation on FTE.bashby has a very good reputation on FTE.bashby has a very good reputation on FTE.bashby has a very good reputation on FTE.
95 PSD cutting out
I'm working on my dad's 95 F350 4x4 PSD MT. It has had this problem for a few years, seems to be getting worse. Driving along it will shut off for 1/2 or sec at a time repeatedly, causing it to jerk real bad. Sometimes it will actually stall but starts right back up. I was going to check codes manually, dont have a scanner, but I don't see a self test input terminal. I went to Fordfuelinjection.com, and looked where they say it is on the efi trucks, no dice. There is what looks like a diagnostic connector under the dash to the right of the steering wheel but it doesnt have the single self test connector. Can I get codes manually on this truck?
__________________
92 F250 4x4 7.3idi zf5 3.55's Meyer plow
86 F350 2wd C&C Dump 351w C6 4.10s Meyer plow
The rest of my signature changed as to not offend some liberal crybaby.
  #2 (permalink)
Old 12-13-2011, 09:59 AM
fordpride's Avatar
fordpride fordpride is offline
Never done with mods
1997 Ford F-250
fordpride is a splendid one to beholdfordpride is a splendid one to beholdfordpride is a splendid one to beholdfordpride is a splendid one to beholdfordpride is a splendid one to beholdfordpride is a splendid one to beholdfordpride is a splendid one to beholdfordpride is a splendid one to behold
Sounds like a bad CPS (camshaft position sensor)
__________________
Mike. 97 F250 totaled 11/19/12 B.E.S.T. map Louisiana FTE Member Map
2012 Ram CC 1500 5.7 Hemi
Diablo sport trinity hemi fever tune, 87mm throttle body, BBK headers, HF cat, 14" magnaflow, AFE intake, 180* T-stat. All waiting for time to be put on.
When married you have two simple choices. You can be "Happy" or you can be "Rite" you can't have both
  #3 (permalink)
Old 12-13-2011, 11:04 AM
bashby's Avatar
1992 Ford F-250
That was my first thought, just hate throwing parts at it.I tried tapping on the crank sensor... no change but I dont know if thats a good test on these or not. I used to do that a lot on gassers for cam and crank sensors and you could usually get them to act up.
__________________
  #4 (permalink)
Old 12-13-2011, 11:22 AM
fordpride's Avatar
1997 Ford F-250
The only test for a CPS is to replace it
__________________
  #5 (permalink)
Old 12-13-2011, 11:37 AM
bashby's Avatar
1992 Ford F-250
Whats the concensus on aftermarket ones? Autozone has it for $20 but I'm leaning towrds NAPA for I think $30 or so, and I'm getting a new fuel tank from them today anyway ($109 for the rear one). I'd still like to know if I can check codes without a scanner if anyone has any insight to that. I think I checked codes on it a while back when I had access to a scanner and came up with none, and there has never been a CEL that I know of.
__________________
  #6 (permalink)
Old 12-13-2011, 11:53 AM
madpogue madpogue is online now
1995 Ford F-250
madpogue has a good reputation on FTE.madpogue has a good reputation on FTE.
Get a CPS from an International dealer, if possible.
When the engine cuts out, but the tranny is still turning the engine as you go down the road, does the tach drop to zero or does it keep reading?
  #7 (permalink)
Old 12-13-2011, 12:25 PM
BuckHammer's Avatar
BuckHammer BuckHammer is offline
1996 Ford F-250
BuckHammer has a good reputation on FTE.BuckHammer has a good reputation on FTE.
Pilgrim812
Get a Motorcraft or International CPS. Accept no substitutes.
__________________
Joseph
1996 F-250 XLT 4x4, "Heavy Metal", 7.3L Powerstroke, ZF S5-42 transmission with Valair clutch and flywheel, Supercab, 8' bed, Riffraff 6637, HPX, Dieselsite 203 degree thermostat, 3" Downpipe to 4" straight pipe exhaust.
"you are not a troll. a pain in the --- sometimes, but not a troll." - tjc transport
  #8 (permalink)
Old 12-13-2011, 12:44 PM
stainlessstroker95's Avatar
stainlessstroker95 stainlessstroker95 is offline
Garage is empty, add now
stainlessstroker95 is gaining momentum as a positive member of FTE.
Have you tried cleaning the fpr screen?
__________________
Gabe 95 f250 4x4 super cab psd, zf 5 speed, 6637 air intake, scan gauge, stancor gpr, ccv mod, 140v IDM, HPX line, irate t4 mount, s366 turbo, i/c, 3" plenums, diamond eye ss 4" exhaust, 3" dp, irate regulated return, short throw shifter, Valair kevlar/ceramic clutch, 35" bfg, d60 RSK V codes , scorpion bed liner, custom tailgate. 96 f350 4x4 psd, dually flatbed welding truck, zf 5 speed, stock. 79 bronco, 351m, 33" swampers.
  #9 (permalink)
Old 12-13-2011, 06:39 PM
bashby's Avatar
1992 Ford F-250
Quote:
No.. not sure what that is but I'll search it. I picked up a cps from Napa, hopefully it will work as well as an oem. Didnt get to try it out, had to replace the fuel tank and that didnt go well. Fought the quick disconnect for .5 hr+... they should call them quick connects, they do that fine but when it comes to disconnecting them, they can be a real PITA. I'm gonna replace the cam sensor tommorow or the next day when I can get back over there, I'll post results. I'm still wondering if you can check codes manually.
__________________
  #10 (permalink)
Old 12-13-2011, 09:29 PM
The fpr screen is on the drivers side of the fuel bowl towards the top in the regulator. You can take the fuel filter out and you should see a lil hole on the inside of the bowl top drivers side. Take a q tip and cut the cotton part off and use the stick part to wipe the screen off through the hole. Or you can take the regulator apart toget to it. Some one on here should have a pic to show you. My truck would cut out every now and then and that fixed it for me. Thanks again copedawg.
__________________
  #11 (permalink)
Old 12-18-2011, 11:20 AM
Ford4Life7.3's Avatar
Ford4Life7.3 Ford4Life7.3 is offline
1995 Ford F-350
Ford4Life7.3 has a good reputation on FTE.Ford4Life7.3 has a good reputation on FTE.
Any updates? Mine just started doing the same thing yesterday. Hoping the parts place is open at ford today since i need the truck tomorrow. The one i have now is the crappy napa one. Its lasted 1.5 months. Shows what theyre worth.
  #12 (permalink)
Old 12-22-2011, 06:46 PM
bass-n-fire's Avatar
bass-n-fire bass-n-fire is offline
bass-n-fire is starting off with a positive reputation.
Mine is doing the exact same thing. Replaced the CPS, fuel filter, and cleaned the FPR screen. No dice, still doing the same thing. I have performed the ohm check on the injectors and everything is within range, very little variation between all 8.
__________________
1997 F350 CC long bed, 4X4, 7.3 PS 180k miles
  #13 (permalink)
Old 12-22-2011, 07:37 PM
fordpride's Avatar
1997 Ford F-250
Have you checked the TPS for a dead spot
__________________
  #14 (permalink)
Old 12-22-2011, 08:19 PM
bearhugger bearhugger is offline
bearhugger is starting off with a positive reputation.
Can anyone tell him if he can check codes without a meter.
  #15 (permalink)
Old 12-22-2011, 08:22 PM
I don't know about the original post, but, mine never threw any codes. As far as the TPS, I was told you could check it by using cruise control to see if it still acted the same. I tried the cruise control and it made no difference at all.
Not trying to hijack any posts, I'm just frustrated. As I'm sure the other people that are having this problem.
__________________
Tags
95, cam, cut, cuts, cutting, diesel, driving, engine, f250, power, powerstroke, psd, sensor, shifting, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
