Brake light ON DASH stays on - Ford Truck Enthusiasts Forums
Old 12-13-2011, 08:45 AM
WyoFlyFisher's Avatar
WyoFlyFisher WyoFlyFisher is offline
WyoFlyFisher is starting off with a positive reputation.
There is another thread going involving break lights on back of truck staying on, but my problem is that the light on the dash is staying on all the time (when truck is running).
Where should I start the troubleshooting for this?
F250 1979 Ranger Lariat 4X4
<input id="gwProxy" type="hidden"><!--Session data--><input jscode="leoInternalChangeDone()" onclick="if(typeof(jsCall)=='function'){jsCall();} else{setTimeout('jsCall()',500);}" id="jsProxy" type="hidden">
Old 12-13-2011, 08:52 AM
Grubbworm's Avatar
Grubbworm Grubbworm is offline
Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.
It could be a bad proportioning valve, a mis-adjusted brake switch (the one touching the brake pedal arm), a front or rear brake issue, a master cylinder issue, just to name a few. I would go over each thing individually and check for any wear or damage, replace, repair, or adjust accordingly. You can get a proportioning valve at the junk yard. I would get a guarantee that it will work, whether or not it fixes the issue. Good luck.
Old 12-13-2011, 08:57 AM
Quote:
I was going to start with the switch because they are cheap, but I wasn't sure that would be the problem since the rest of the brake system, including lights, seems to work fine. Is it possible to still be the switch considering all this?
Old 12-13-2011, 09:29 AM
bamaf150's Avatar
bamaf150 bamaf150 is offline
bamaf150 is gaining momentum as a positive member of FTE.
I don't think your brake light switch, located on the pedal, will have anything to do with the brake light on your dash staying on. The other thread is covering this as well, it got sidetracked momentarily. I'm no expert but it either indicates a pressure loss somewhere or the switch on the proportioning valve is not centered/or bad. FWIW, Chiltons has a procedure for centralizing the pin in the valve after bleeding:
1. turn ign to ACC or ON
2. check fluid in the MC and fill to 1/4 inch from the top.
3. depress brake pedal and the pin should recenter itself
4. turn switch off
5. check operation of brakes be sure firm pedal is obtained.
Old 12-14-2011, 09:02 PM
RunninD's Avatar
RunninD RunninD is offline
RunninD is gaining momentum as a positive member of FTE.
Another area to go bad is in the sensor wiring in the harness. To check it you can start by jumping across the studs at the pedal switch. if the lights go off there you go. Next would be to check continuity in the wiring outside the cab on the DS inner fender. The wiring harness comes out in a group and separates into the front light harness and the set going down to the proportioning valve. You can also check the proportioning valve switch. ordinarily it will be one of the three. Until I fix my breaks I just removed the bulb!!!
Old 12-14-2011, 09:33 PM
fmc400's Avatar
fmc400 fmc400 is offline
MSEE
fmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud of
This light goes on when the proportioning valve senses a pressure differential between the front and rear brake circuits. The switch inside the valve can also short out, and keep the light on permanently. It has nothing to do with the stop lamp switch.
Try recentering the valve as Bama described. If the brake pedal is firm and you're confident there are no issues, then it's likely a shorted proportioning valve switch.
Old 12-14-2011, 09:51 PM
The Peddler's Avatar
The Peddler The Peddler is offline
The Peddler is starting off with a positive reputation.
Quote:
Is there not a switch in the E-brake/Parking brake mechanism to trigger the light when the parking brake is engaged?
Old 12-14-2011, 09:57 PM
fmc400's Avatar
MSEE
Quote:
Sedans yes, but not in this era of trucks.
Old 12-14-2011, 10:25 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
You can unplug the electrical connector from the proportioning valve, the dash lamp should then go off.
(If it doesn't, there is a short to ground somewhere in that wire.)
Ground the terminal in the connector to the body or engine, the light should go on.
In the case of a failing master cylinder, there will be a pressure differential between the front & rear circuits; the pin (connected to the wiring) will get pushed to the low-pressure side, where it grounds out and lights the lamp.
Those proportioning valves can be disassembled & cleaned, too.
http://www.ford-trucks.com/forums/11...lve-issue.html
ABS Light and Speedometer jeffleard 1997 - 2003 F150 1 12-07-2013 05:21 AM
Heater not getting warm WyoFlyFisher 1973 - 1979 F-100 & Larger F-Series Trucks 14 12-15-2011 04:22 PM
Riff Raff Hoodies patrickke General Diesel Discussion 42 12-01-2011 05:34 PM
1959 ford switch help ptra2417 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 05-28-2011 12:28 PM
Best SI/SO bolt on exhaust for my 2010 4.6 3v 06sonicsport4x4 2009 - 2014 F150 9 09-10-2010 06:18 PM
Tags
150, 1978, 2006, 73, brake, dash, excursion, f100, f150, ford, light, porportioning, ranger, stays, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
