Is it as simple as changing tail shafts on a (small block pattern) 2wd C6 to convert it to a 4wd C6? Sorry for so many newbie questions but im kinda stuck and need info so I can get my truck back up and running! Thanks to all for the help!
Not 100% sure for the auto trannies, but I know for the standard trannys, so convert from 2wd to 4x4, the entire tranny has to be tooken apart, as the main shafts inside aren't the same length.
In a way it is as simple as changing the tailshafts and bolting on the transfer case adapter. However as IDI says you need to completely dissassemble the trans to do it.
