2.8 valve adjustment - Ford Truck Enthusiasts Forums
Bronco II Ford Bronco II
Old 04-15-2003, 09:03 PM
ford85 ford85 is offline
ford85 is starting off with a positive reputation.
how are adjusters locked into place ? I tried to turn adjuster but it felt really tight , was afraid of breaking it
Old 04-16-2003, 09:02 AM
Matt_W Matt_W is offline
Matt_W is starting off with a positive reputation.
You will neen a regular screwdriver and a boxend wrench that fits the rocker nut. You need to loosen the rocker nut about half a turn and then you should be able to turn the adjustment screw. When you are done tighten up the rocker nut again and the screw will lock in place.
Old 04-16-2003, 06:33 PM
the valve adjusters do not have a screwdriver slot only a hex head on them they do not have a jam nut the adjuster is hollow
Old 04-16-2003, 09:29 PM
Oceanwave Oceanwave is offline
Oceanwave is starting off with a positive reputation.
Engine Cold! DX coil wire & ground to block. put finger on #5 intake & bump a little at a time until rocker arm starts to open valve. With engine in this pos you can adj valves for # 1. Intake valve 0.014", Exhaust valve 0.016". Use the following guide to adjust all valves.
Intake Valve Opening On Adjust Valves for Cylinder #
1 5
4 3
2 6
5 1
3 4
6 2
I usually run them around twice just in case, because I hate pulling all the stuff off to get at them. I set them Spring & Fall and she purrs like a kitten.
JK
Edit.
Yes the lock nuts are probably very tight, most people have never adjusted them. Use a 6 point box wrench and you should be ok.
Old 04-17-2003, 12:35 AM
pat67shorty's Avatar
pat67shorty pat67shorty is offline
pat67shorty is gaining momentum as a positive member of FTE.pat67shorty is gaining momentum as a positive member of FTE.
In addition to the above: The adjusters are an interferance fit, they are tight so that the lash doesn't back off.
Tie Rod End adjusting sleve.. afonda 1999 - 2003 7.3L Power Stroke Diesel 4 01-28-2014 02:44 PM
Brake adjust. what order obscurity 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 06-30-2013 08:15 PM
adjusting valves? merc62 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 4 03-09-2005 12:59 AM
rocker arm adjustment ford390gashog FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 6 11-01-2004 09:27 PM
LINKAGE ADJUSTMENT Burple 1987 - 1996 F150 & Larger F-Series Trucks 2 12-27-2002 11:08 AM
Tags
28, 85, 86, adjust, adjusting, adjustment, bronco, c4, cyl, ford, ii, valve, valved, valves, vavles
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
