2001 f250 gauges not working - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 12-12-2011, 08:43 PM
dlaroche1 dlaroche1 is offline
dlaroche1 is starting off with a positive reputation.
My trucks gauges have quit working. They sometimes come back but don't work long. I have changed the shifter handle out and did find the wire chaffed, but still no gauges. I have the small fuse box, so no fuse 41,45 etc... the shifter problem blew the #19 fuse once, but this was after the gauge problem started. Checked for power to cluster and found the ignition source to be working as well as the keep alive and the ground checked out also. It's strange when it comes back to life at random times like sitting at a stoplight or just idling along in traffic. Everything else seems to work fine. Any ideas? Thanks.
Old 08-01-2013, 08:07 AM
wileyeyejeep's Avatar
wileyeyejeep wileyeyejeep is offline
wileyeyejeep is starting off with a positive reputation.
I have same thing going on. What was the fix?
2006 F350 gauges not working - Check Gauges / TBC Fault / Warning Lights rotaryracer 1999 to 2016 Super Duty 25 11-23-2016 05:08 AM
99 7.3 4wd NO GAUGES OR ACCELLERATOR 393spina 1999 - 2003 7.3L Power Stroke Diesel 1 12-09-2014 07:27 PM
dead cluster lights/gauges TwistedLefty 1999 to 2016 Super Duty 1 11-20-2014 02:01 PM
no gauges work . scottking990 1997 - 2003 F150 10 03-01-2014 03:07 PM
97 F150 Blowing fuse for gauges dbcooper 1997 - 2003 F150 3 10-13-2010 04:19 PM
Tags
2000, 2001, cluster, f250, ford, fuse, gauges, guages, inop, nt, quit, radio, superduty, work, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
