Found me a new flareside bed!
I had recently gotten back from a road trip, right around thanksgiving time, and decided to check craigs list for ****s & giggles to see if there were any beds for sale, well, I found one! Amazing shape for being up here in connecticut. Only one rust hole on it, the size of the tip of my pinky. It was on an 87 truck, I had the JY take it off for me, and I trailered it home. My old bed was absolutely rotten, there was even plants growing out of the wood, and one side was collapsed.
This is what I have been working on the last few days:
My old bed from the back:
Nastyness:
Making progress:
The old wood was crumbling like a cookie:
All done taking the old one off:
The new bed:
The only rust hole on it, very minor!
Hit the supports with a wire brush then some rust to primer converter:
Mounting it up by myself:
And done!
Now unfortunately when I was mounting it, it slipped off of a board a little bit and kinda made a 3/4" long crack in the rear corner of the right fender, but that can easily be fixed, guess that's what I get for mounting it by myself. I also left the small carriage bolts up front, un bolted because the PO of the bed had misaligned the holes for them when he drilled them on each plank, making it near impossible for me to get the nuts on, which is fine because eventually I will replace the wood, with metal.
I also swapped over the mount for the filler neck, and fuel door from my old bed to the new one as they were n better shape. All I have left to do is hook up the other lights, and tighten a few more bolts & screws and then it is done. And I have an extra tailgate, set of fenders, front panel, steps, and rear lower mounting panel, still un decide if I am going to keep, or sell those.
I am glad I found this bed, I was gong to make all new sides and such from scratch, but this was definitely way easier!
Nastyness:
Making progress:
The new bed:
And done!
Pretty sweet deal. Other than *slightly* different wheel openings on the fenders, it looks like it was made to fit the truck.
Personally, I prefer the even newer 92-96 flairside bed. It has a metal floor, and the tailgate works just like a wide (styleside) bed gate does. No chains and dual latches to deal with. Plus, it's double wall, like the styleside beds. Of course, the entire outer bedside is 1 piece fiberglass. Never dents, cracking/breaking instead. Also uses the flush mounted lights like the styleside.
I wasn't aware (didn't really care, to be honest) that the flare's went away for a few years..... I don't care for short bed trucks, and narrow beds are even less useful. I don't use a truck as a status symbol, I use them like a truck. My B2300 (Ranger w/Mazda badges) can handle the same volume of cargo as a flareside, and uses a lot less fuel to do it.
Almost forgot an ironic twist. My 95 B2300, which is nothing more than a Ford Ranger with Mazda badges, has the same "flat top" wheel opening profile as the 80-86 F-series and 83-92 Ranger, while the 95 Ranger uses the rounder profile like the 87-96 F-series. Might be part of the reason I like the looks of the Mazda-badged version better than the same year model Ranger.
Rogue, just went out and saw what you were talking about! I had noticed that something didn't look exactly the same as before, but only thought that was because I hadn't finished positioning/mounting the bed yet, and after it was all done, I was to excited to notice! I don't really use this truck for work at all, it's primarily to off road with, something it does extremely well, especially with the NP435, 33" Mt's, factory limited slip front & rear and the short wheel base.
Brad, I may just end up swapping the old fenders back onto this bed! Attached a picture of both left bedsides so everyone can see the difference.
From the 82:
From the 87:
From the 82:
From the 87:
Yep, very minor difference, that can be easily missed. The same goes for putting a wide bed on, the 87+ fits just fine, but the fender lips differ the exact same way. Lots of people are running around with 80-86 and 87+ mismatched truck/beds, and don't even know it.
For an off-road use vehicle, the flareside would be my first choice. That little bit narrower tailgate and upper portion of the bed can come in handy in some tight spots, and the shorter wheelbase is also a bit more manuverable.
...I prefer the even newer 92-96 flairside bed. It has a metal floor, and the tailgate works just like a wide (styleside) bed gate does. No chains and dual latches to deal with. Plus, it's double wall, like the styleside beds. Of course, the entire outer bedside is 1 piece fiberglass. Never dents, cracking/breaking instead. Also uses the flush mounted lights like the styleside.
On the other hand, with a little fab work, one could stuff some rather wide tires under the back of a ranger with the later flareside bed on it.......
