Baffled by no heat!!
no heat
hi there i'm going through the same thing on my f150 5.4. If you search the heater treater fix, in the steps for this it shows you how to get at the heater core and ac condenser from behind the glovebox. I did this in 10 - 15 min with a dremel. You can feel the whole surface of the core and watch the blend door and other doors working as you switch the selector. Just a thought. good luck
Still working towards heat in Oregon, PK
Has the heater core been replaced? If it was and the seal that wraps around to core was left out cold air will bypass the core and dilute the incoming air. This will give warm-hot air while setting and cold air while moving due to the increased air flow. Grab the heater core tubes under the hood and try to wiggle them. If they feel loose the seal is missing.
That sure sounds like a heater core that has plenty of hot coolant going through it very nicely, but with no AIR FLOW to remove and distribute the heat.
Any chance you could get someone to take over driving it once its well warmed-up, while you check that blend door position while cruising along?
Oh yeah, remember to wear your seat belt, too
My two cents,
Steve
98expedition98
1997-2006 Expedition & Navigator
03-10-2007 09:04 PM
91XplorerXLT
01-15-2004 03:52 PM
83_f150_me
13
10-29-2003 08:11 AM
