Transmission id please
Old 01-22-2012, 11:23 AM
nikmish's Avatar
nikmish
nikmish is offline
Hi there!
I've been looking around the forum, but still can't figure out for sure what transmission my truck has. I took some pictures last night and hope you might be able to see. The gear pattern is like this:
R 1 3
2 4
Old 01-22-2012, 11:35 AM
Sw1tchfoot's Avatar
Sw1tchfoot
Sw1tchfoot is offline
It's hard to tell, but doesn't that say "Tremec" under all that grease?
It could be the 4 speed, 4th gear being overdrive.
Old 01-22-2012, 05:23 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
81-F-150-Explorer is offline
Shift pattern for the Clark (AKA: Tremec) 4 speed overdrive:
R-1-3
--2-4
The **** will say push next to the R as you have to push down then over to get it into reverse.
Look at the safety certification lable on the drivers cab "B" pillar next to the door striker bolt.
Under Trans if it came with a Clark (Tremec) 4 speed overdrive from the factory, it will have a CODE B.
Jmlcolorado
02-07-2022 07:05 PM
Twinibeam1
07-22-2018 07:31 PM
aj64f100390-292
02-20-2017 01:52 PM
1972RedNeck
40
09-13-2015 03:23 AM
xjpilot
13
08-13-2010 08:25 PM
Quick Reply: Transmission id please
