How to reset the computer on a 2005 F-250 w/ 6.0L Diesel - Ford Truck Enthusiasts Forums
Old 12-12-2011, 12:05 PM
fordtruckf-100 fordtruckf-100 is offline
fordtruckf-100 is starting off with a positive reputation.
Hello, i got a 2005 F-250 with a 6.0L diesel and i would like to reset the computer in it if possible. I had a SCT tuner in it and just wondering since i returned the computer to stock and am getting rid of the chip, is there any way of reseting the computer to get a better chance of not leaving a fingerprint of a chip??? I unhooked both batteries both + and - and i will let it set for a couple hours. Anything else to try?? I was told that my tuner would not leave a fingerprint but i just dont want to chance it. Thanks!
Old 12-12-2011, 12:10 PM
zhilton's Avatar
zhilton zhilton is offline
zhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to all
Unhook both batteries and turn the headlights on. Give it about 5-10 minutes to make sure the capacitors are good & drained. Hook both batteries back-up and your back to default settings until the truck has enough time to re-learn your driving style.
Old 12-12-2011, 12:59 PM
Striderwv's Avatar
Striderwv Striderwv is offline
Striderwv is gaining momentum as a positive member of FTE.
Here's how to unhook an hook back up.
Dual Battery Disconnect - Ford Truck Enthusiasts Forums
Old 12-12-2011, 01:01 PM
ok do you think that after that can they find out there was a chip in it?
Old 12-12-2011, 02:30 PM
zhilton's Avatar
Quote:
You don't chip the 6.0L...you "tune it" with software flashes. Now if the truck was tuned...unless you've replaced it with something; I think it will keep that tune even after unhooking the batteries. Not 100% sure since I'm running a stock tuned truck.
Old 12-12-2011, 02:39 PM
SteveBricks's Avatar
SteveBricks SteveBricks is online now
***** Emeritus
SteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputation
That depends on who "they" is...I'm pretty sure Ford could find out if they really wanted/needed to.
Old 12-12-2011, 08:21 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is online now
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
I know with 100% certainty that a Ford dealer can find that information no matter what you do to reset the computer.
Old 12-12-2011, 09:25 PM
lenzhotrod lenzhotrod is offline
lenzhotrod is starting off with a positive reputation.
And if it had a SCT tuner on it he needs to reload the stock program. Disconnecting the battery will not return it to stock. It will only go back to "tuned defaults". Looking at your post again it says you returned it to stock. That is about the best YOU can do. Like stated earlier if they want to look they can find. Wait until insurance companies start LOOKING into our vehicle computers all the time.
Old 12-13-2011, 09:19 AM
ok well i will just take my chance. Im looking to trade it in today and so i dont know if they will hook it up tho the computer right away or not???
Old 12-13-2011, 04:30 PM
If they are not specifically looking for evidence of a tuner they won't see it.
Old 03-03-2016, 09:13 PM
papa56 papa56 is offline
papa56 is starting off with a positive reputation.
My 06 Ford F-250 will not run right when tach seedometer not working right can you tell me why
Old 03-03-2016, 09:20 PM
dscabra's Avatar
dscabra dscabra is offline
dscabra is gaining momentum as a positive member of FTE.dscabra is gaining momentum as a positive member of FTE.
Quote:
You would be best served if you create a new posting and include as much detail as you can on what your truck is doing.
Old 03-04-2016, 06:05 PM
Quote:
My 06 Ford F-250 6.0 motor when I start it up the tach not working and speedometer showing 40 mpg and I going faster that pickup has no power and when tach and speedometer are working right pickup runs good
Old 03-04-2016, 07:32 PM
bobv60 bobv60 is online now
bobv60 is gaining momentum as a positive member of FTE.bobv60 is gaining momentum as a positive member of FTE.
You should start a NEW thread with more info. It could be a number of things though. Does you gages, radio and power windows ever stop working while you are driving?
Old 03-04-2016, 08:37 PM
06ford f250 when tach is stuck at 1800 rpm and speedometer not working right truck has no power when tach and speedometer are working right it runs better
Navigation Screen Cleaning ??? Rongold 1999 to 2016 Super Duty 8 05-27-2016 08:04 PM
F250 computer won't reset for smog Crdrtdvl 1999 to 2016 Super Duty 1 08-27-2015 08:52 PM
2006 6.0 straight pipe question rhrs2414 6.0L Power Stroke Diesel 4 10-26-2013 09:18 AM
Was my FICM really replaced?? jampen 6.0L Power Stroke Diesel 3 08-29-2011 06:16 PM
best fuel milage chip for 6.0 psd mackdog Computer Chips & Tuners 3 07-07-2008 04:05 PM
Tags
2004, 2005, 2008, 250, 60, 60l, computer, diesel, f250, ford, fuel, motor, relearn, reset, resetting, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
