84 F250 460 flatbed restore project (WAS: New guy intro w/460 questions...Pics Added...) - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 12-13-2011, 11:49 AM
ArdWrknTrk ArdWrknTrk is online now
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
Leave the egr plate in place and block it off where it bolts to the plate or you WILL have an exhaust leak.
It also acts as a spacer and the throttle linkage and air cleaner will sit too low
You probably want to hook up the heated air intake.
It gets plenty cold in north Dakota and these 460's are cold blooded beasts to begin with...
  #32
Old 12-13-2011, 01:00 PM
Bump187's Avatar
Bump187 Bump187 is offline
Bump187 is starting off with a positive reputation.
That is just the 1-1/2" or so tube from the exhaust manifold to the intake right? If so that's still there.
  #33
Old 12-13-2011, 06:10 PM
pedant
Yes.
But it needs to be functional.
The Bi-Metal disc inside the air cleaner helps the truck warm up quite a bit faster than if it were only breathing cold air.
  #34
Old 12-13-2011, 07:48 PM
kedwinh's Avatar
kedwinh kedwinh is offline
kedwinh is gaining momentum as a positive member of FTE.
Man I'd love to have a 460, just can't afford to feed it.
  #35
Old 12-13-2011, 07:54 PM
lavatan's Avatar
lavatan lavatan is offline
lavatan is gaining momentum as a positive member of FTE.lavatan is gaining momentum as a positive member of FTE.
If spacing is an issue you can always buy a phenolic spacer. They come in all sorts of sizes. I just plugged the hole into the intake and I don't have any vacuum leaks. I also don't have a spacer installed and I removed the EGR. The carb and air cleaner fits just fine. Just my 2 cents.
  #36
Old 12-14-2011, 02:51 AM
Swatter's Avatar
Swatter Swatter is offline
Swatter is starting off with a positive reputation.
QUESTION 7: The above noted connector has been “jumpered” with a piece of wire.
It looks like the plug that goes to the oil pressure cutoff located on the top of the engine behide the carb. I keep mine jumpered because i've had no luck finding the replacement part.
  #37
Old 12-14-2011, 03:52 AM
pedant
I don't know.
The oil pressure sender behind my EGR looks like a small tin can with a single wire on top.
I have a mechanical fuel pump, and no need for that wiring related to the hot fuel handling system.
But according to the schematic I'm looking at, it is a red wire with a yellow tracer.
  #38
Old 12-14-2011, 04:22 AM
Swatter's Avatar
The tin can with a single wire is the sender for the dash. The other one back there kills power to the fuel pump(s) in order to save the engine.
  #39
Old 12-14-2011, 04:55 AM
Swatter's Avatar
Beware of those cheap gaskets between the intake and EGR plate. In most cases they need doubled up or cut from quality material.
  #40
Old 12-14-2011, 05:28 AM
pedant
I had to buy a pack of 10 EGR spacer gaskets from Ford.
PM me with your address if you need one.
  #41
Old 12-14-2011, 05:30 AM
pedant
Quote:
I understand this, that's why i made the distinction between the gauge sender and the idiot light sensor.
If it were functional, at least the truck wouldn't completely destroy itself due to a lack of oil pressure.
  #42
Old 12-14-2011, 06:32 AM
85lebaront2's Avatar
85lebaront2 85lebaront2 is offline
Old School Hot Rodder
85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold
I have a good oil pressure switch that matches that plug I just removed from mine. Archion may know of a source for it.
  #43
Old 12-14-2011, 06:48 AM
Bump187's Avatar
Wow. Thanks for all the help guys. Unfortunately I spend most my time working on these projects on the weekends. Planning on going to get a rebuild kit for the carb this afternoon.
Quote:
Im not looking fwd to the fuel in this thing, but its definitely not a daily driver, but I have a feeling its going to grow on me more and more to want to drive.
Hopefully some of the fuel cost will be off set by the $0 purchase price!
  #44
Old 12-14-2011, 07:14 AM
Mtnplow Mtnplow is offline
Mtnplow is starting off with a positive reputation.
Wow nice truck would love to find one in that good of shape. Between 85Lebaren and me we have a few wiring harnesses and figured out all the wiring and vacuum lines. A lot of that crap is early smog attempts. On the thermostat housing there are 2 sensors and 5 vac lines. Looks like someone replaced that carb and it appears that the one wire may be for the electric choke. If you are going back to basics you can run vac to the egr and vac to the dist adv and be done with it, the one plug you have in your hand I believe is the oil shutoff plug at the rear of the manifold under the oil sender.
  #45
Old 12-14-2011, 08:46 AM
Bump187's Avatar
Great! I may have to hit you up on info for that next week after I tear into it again this weekend.
A guy I work with gave me two Haynes manuals this morning. This should be very helpful.
80-86 Ford Pickups and Broncos
80-96 Ford Pickups and Broncos
wrecked 4X4 F150 Build Thread Staveys150 1987 - 1996 F150 & Larger F-Series Trucks 74 03-23-2014 07:03 PM
Problems aligning running boards-pics jrockdiddy 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 12-11-2012 10:41 PM
Unibody Lightnning unibodyslick 1961 - 1963 F100 Unibody 9 10-15-2011 04:08 PM
Pics yes pics of my 1948 F1... Cody_1948 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 06-17-2011 11:04 PM
63 Uni Project unibodyslick 1961 - 1966 F-100 & Larger F-Series Trucks 36 06-01-2011 03:31 PM
Tags
2004, 460, 4x2, 87, carb, cover, crewcab, deisel, diagram, f350, ford, kit, pump, rebuild, rgaw, smog, vacuum, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
