Cruise Control won't work! - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 12-11-2011, 03:51 PM
Frankiels3 Frankiels3 is offline
Frankiels3 is starting off with a positive reputation.
Okay this is been a reoccurring problem.
My cruise control sometimes works and sometimes doesn't.
Sometimes if I push it hard and repeatedly it works, sometimes not. Now I can't get it work at all and I have an 18 hour drive in the AM early!
Please advise!!
2003 EB Expedition 4x4 5.4
Old 12-11-2011, 07:21 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Nothing like waiting until the last minute.... you'll need to use your right foot, there isn't sufficient time.
Old 12-11-2011, 07:30 PM
Well thanks for that!
I never use CC as I drive only in the city, that's why it's "last minute" because I didntbknow it was fully not functioning....
Now what is it I don't have time for?
I'd like to have the info so I can repair when I have time
Old 12-11-2011, 08:44 PM
Diverdom Diverdom is offline
Diverdom is starting off with a positive reputation.
Sounds like the problem I had with my old Sport Trac. What it was is the brake like switch that was attached to the pedal. We were on a trip and the cruise stopped working, I got under the dash and tapped on it with a screw driver and sprayed it with electrical cleaner. Worked great for about a year and I fixed it the same way again. To lazy to go buy a new one. Hope this helps.
Dom
Old 12-11-2011, 10:32 PM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Quote:
If by push you mean the CC buttons, then I'd replace the switch assembly.
http://www.rockauto.com/catalog/rafr...&parttype=4320
Old 12-12-2011, 05:41 AM
Hmm I'm really starting to think its the switch as sometimes it lights up and sometimes it doesn't, but it never stays on. I assume it's not getting power. Bad thing is I can wait to get one from Ford this morning but I'm assuming it will be crazy expensive?
Old 12-12-2011, 04:20 PM
Maybe the connector on the back of the switch isn't in all the way. That would explain why pushing on it hard can make it work.
Cruise Control 99F350bigorange 6.4L Power Stroke Diesel 9 03-24-2015 11:07 PM
2004 Ford Explorer Steering Wheel Controls Funky Wranglin4Life Explorer, Sport Trac, Mountaineer & Aviator 1 10-30-2014 12:07 PM
Cruise control slowly loses speed.. argh... leinhit 1997 - 2003 F150 4 09-16-2012 12:08 PM
Cruise control only works ocassionally bossgobbler 1999 - 2003 7.3L Power Stroke Diesel 9 05-10-2012 10:30 PM
cruise control on 2001 F250 B Bushman 1999 to 2016 Super Duty 5 08-05-2008 08:41 PM
Tags
03, 04, 2008, 2010, 54, control, cruise, cruse, f150, f250, lincoln, navigator, wont, work, working, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
