1970 F250 rear brake drum removal - Ford Truck Enthusiasts Forums
Old 12-11-2011, 03:42 PM
dlo3575 dlo3575 is offline
dlo3575 is starting off with a positive reputation.
I got a 1970 F 250 Ranger. I had a wheel cylinder go out (leaking brake fluid). I got the tire off, and removed the axle cover and took out the axle. I am having an issue removing the LARGE nut holding on the bearings and drum. Is there a special tool for the nut removal? Here is a picture of my situation! Thanks.
Old 12-11-2011, 06:52 PM
GLR's Avatar
GLR GLR is offline
GLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputation
There is a special socket (2 3/8" ??). Open the tabs of the lock first. Some have used a center punch or a chisel to remove the nut. Behind the locking tab is another nut.
Old 12-11-2011, 08:44 PM
tool?
Quote:
How do i open the "tabs"? What are tabs? I see there are some teeth or studs sticking out from behind the nut. I assume this is going to be a real bugger, given the chisle marks present.
Old 12-11-2011, 09:19 PM
grinnergetter's Avatar
grinnergetter grinnergetter is offline
grinnergetter has a good reputation on FTE.grinnergetter has a good reputation on FTE.
Some of the tabs should bent around the nut on the flat part of the nut.. Use a chisel to straighten them out and pick up the proper socket. They are under 20 at the parts store.
Old 12-11-2011, 09:23 PM
19704X4F250's Avatar
19704X4F250 19704X4F250 is offline
19704X4F250 is a name known to all19704X4F250 is a name known to all19704X4F250 is a name known to all19704X4F250 is a name known to all19704X4F250 is a name known to all19704X4F250 is a name known to all
Yes, there is a nut but behind that nut is a ring with locking tabs that are bent to the side of the nut to keep it from turning. Use a small chisel to bend (not cut) those tabs away from the nut. The nut will then come off. Then the ring with the tabs, then the other nut. http://fordification.com/tech/images...llFloating.jpg
Old 12-12-2011, 09:41 AM
THANK YOU
I do beleive you boys got me on the right track. I will go to the part store and see what i can find. I wonder what part sotre in our area carries such a large socket. I will call around. THANK YOU for your feedback.
62 F250 -- Rear Brakes ? jawroper 1961 - 1966 F-100 & Larger F-Series Trucks 3 06-02-2015 09:35 PM
Pull Rear Break Drum? fridgeddiesel 1994.5 - 1997 7.3L Power Stroke Diesel 7 10-18-2013 12:14 PM
How do I remove a drum brake, it leaks fluid? paulinkansas 1967 - 1972 F-100 & Larger F-Series Trucks 10 01-06-2011 09:29 PM
Drum Brake Removal 54' F250 - Help! teardropty 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 11-14-2010 04:47 PM
how do i remove axle and brake drum mrblonde108 Large Truck 48 08-25-2010 12:44 AM
Tags
100, 1970f250, 1978, aerostar, brake, cylinder, drum, f100, f250, parts, pictures, rear, removal, remove, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
