PO301 Help Tracking Down - Ford Truck Enthusiasts Forums
Old 12-11-2011, 02:59 PM
State_Tweaker State_Tweaker is offline
State_Tweaker is starting off with a positive reputation.
2001 Ranger 3.0 XLT non-flex fuel.
PO301 (Misfire #1) still popping up. Ignition Wire check good. So it is either the injector or compression. CEL comes on, but ocassionally goes away once in awhile for about 10 minutes.
Rough idle on start up, especially when cold.
Runs okay down the highway, but feel a slight loss in power
Put seafoam in the tank the last 3 refills
Oil is being consumers at about 1 quart every 2.5 weeks (500 miles)
No smoke that I can see
No smells except a hot oil smell on passenger side (same as cylinder 1) when I lean down to get stuff out of the floor board.
Haven't performed a compression test, but have read about the valves receding into head. If that is the case is the solution to replace the head or valves or both?
What do you folks think, and am I going down the right path?
How to clean a Mass Air Flow (MAF) sensor - 5.4L CelticDevilDog 2004 - 2008 F150 18 11-03-2016 05:36 PM
2003 Expedition trouble codes PO301 and PO316 ltramon45 Expedition & Navigator 1 08-21-2013 03:07 PM
codes 95schauf 1994.5 - 1997 7.3L Power Stroke Diesel 3 10-08-2012 11:01 AM
PO 301 Code, Cylinder 1 Misfire bowdog 1997 - 2003 F150 8 02-07-2008 11:13 AM
compression 86 f250? jriley301 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 0 09-19-2004 11:42 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
03, 2001, 30, 301, code, codes, explorer, f150, ford, misfire, po, po301, ranger, v6, warm
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
