Idle goes up and down, help!
I have a 2002 F-350 with a brand new 5.4 motor we just put in. After we first started it we had a problem with the idle going up and down. I sprayed starter fluid all around the intake and vacuum lines, no leaks, no spike in rpms. I replaced the IAC valve and PCV valve, seems to run smoother at an idle until I put it in gear, then the idle goes up and down again. I don't know what else to look for, any ideas? Thanks....
Well I tried everything, new IAC sensor, PCV, cleaned the Ram air sensor, new battery, nothing worked. I took it into the ford dealer and after $500.00 later they found out that I had a bad 02sensor and a bad injector, Truck runs great now, only thing is I have no money left to go anywhere. The 02sensor corrected the idle problem and the injector corrected the miss i was getting every so often. Just want to let you know in case anyone else ever posts an idle problem on here.... thanks....
icrman
06-24-2008 11:48 PM
