Replacing Front Seats - 96 f-250 - Ford Truck Enthusiasts Forums
Old 12-11-2011, 09:04 AM
f_250 f_250 is offline
f_250 is starting off with a positive reputation.
Any ideas on how difficult it would be to replace my 60/40 bench seat on 96 f-250 super cab with powered bucket seats from 99-07 FORD F250?
Old 12-11-2011, 01:35 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is online now
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Quote:
1 welcome to the site
2 use the search function
3 you dont have a 60-40. You could have one of 3 choices. A 40-20-40, split bench, or buckets
Old 12-15-2011, 11:55 AM
Drilling holes for seat brackets??? Safe???
[QUOTE=Diesel_Brad;11140766]1 welcome to the site
Hi Diesel_Brad
I've searched but so far not finding what I'm looking for. Hopefully u might know. I have found a sweet deal on some captain's buckets from a 2003 Expedition. If the seat brackets on the buckets don't match up to my F250 holes, can I just drill new holes and mount the buckets?
I've never added different seats to a rig and don't know if just drilling new holes for the bolts and nuts would be safe.
Any thoughts?
Old 12-15-2011, 02:08 PM
GNR22's Avatar
GNR22 GNR22 is offline
GNR22 has a good reputation on FTE.GNR22 has a good reputation on FTE.
[quote=f_250;11157025]
Hi Diesel_Brad
Any thoughts?
I'll help you out here. I just put in bucket seats from a 93 Probe into my F250. If the holes dont line up, then drill appropriate sized holes through your floor and make sure that your seats line up the way you would like. Then tack weld a washer on the underside of the truck to increase support, because if you hit something you wouldn't want your seat to rip out of the floor. Then put a bolt and nut through, tighten them down, and make sure your seatbelt ends up where you want it. Thats about all there is too it. Oh and i suppose if you really wanted to make it easier on yourself, you could weld the nut to the washer so you dont have to have someone hold a wrench on the nut when you tighten.
Old 12-15-2011, 02:58 PM
THANKS
[QUOTE=GNR22;11157416][quote=f_250;11157025]
Hey, appreciate the help. That's what makes this forum so great - getting help!
dave
Old 12-16-2011, 01:16 PM
GNR22's Avatar
You're very welcome Dave. I agree, this forum is very convenient for getting help.
Old 12-16-2011, 02:02 PM
mreid99 mreid99 is offline
mreid99 is starting off with a positive reputation.
[quote=GNR22;11157416]
Any photos of before and after?
Old 12-16-2011, 11:06 PM
GNR22's Avatar
[quote=mreid99;11161685]
Quote:
I dont have any before pictures, i might be able to take some pictures tomorrow here if I remember or can locate my camera. Im not really liking the probe seats because i hadnt taken into account the lack of arm rest which is kind of uncomfortable. So i might have to find something to use as an armrest or find some other seats.
Old 12-17-2011, 01:35 AM
An update about my seat replacement project: I took a close look at my 40/20/40 front seats in my 96 f250 extended cab and discovered the job will be more difficult than I figured. The floor of the truck has quite a hump where it passes over the tail of the transmission, etc. Ford has mounted the seats on a clever assortment of shaped metal supports that follows the contours of the cab floor and creates a flat platform for the seat tracks. It means I can't simply bolt on new seats to the floor. That narrows down the availability of seats. I've heard that seats from late 80s to 99 f150, 250, 350 extended cab will work. So I continue the hunt!
Want New Front Seat/ Have questions Mike8623 1994.5 - 1997 7.3L Power Stroke Diesel 33 11-17-2016 05:44 AM
Recommendations for seats please 96 F250 Extra Cab DieselFordLoversWife 1987 - 1996 F150 & Larger F-Series Trucks 10 04-19-2015 08:11 PM
old interior to new??? trevorrules 1987 - 1996 F150 & Larger F-Series Trucks 9 11-26-2014 04:34 PM
Swap bench seats for buckets 1992 F250 captained223 1987 - 1996 F150 & Larger F-Series Trucks 6 11-05-2014 03:24 PM
Replacement Seat Options? turnkyle 1987 - 1996 F150 & Larger F-Series Trucks 11 04-10-2011 02:37 PM
Tags
6040, 96, bench, bucket, captian, f150, f250, f350, ford, forum, front, probe, replace, replacement, seat, seats, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
