1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Truck wont start in park..Any ideas?
Old 12-10-2011, 05:45 PM
esloneker's Avatar
esloneker
esloneker is offline
I have a 1999 F250 I cannot start it while it is in park. I am not sure if the truck will even go into park. If a park on a slope I have to put on the emergency brake to keep it from rolling away. So in order to start it I have to put it in neutral. I believe it has something to do with the linkage but I'm not sure. I am wondering if anyone knows how to tighten it up or to fix it another way. Thank you!
Old 12-10-2011, 05:51 PM
Fordfanatic4life's Avatar
Fordfanatic4life
Fordfanatic4life is offline
you def. have a shift linkage adjustment thats wonky..
both of the issues tie in, as in no Park and refusal to start.
Old 12-10-2011, 06:03 PM
Firefighter 1406's Avatar
Firefighter 1406
Firefighter 1406 is offline
X2 on the linkage. Check under the truck on the tranny might be loose or have a adjustment. Could also be your column shifter worn also.
Old 12-10-2011, 06:06 PM
Tugly's Avatar
Tugly
Tugly is offline
Maybe this will help. I had some transmission work several months back and in this last month, "Stinky" wouldn't start in Park every time. It was once in a great while at first, but got more frequent. One day out of town (at the hotel check-in) - zero, nada, bubkes. Nothing but the sound of distant traffic. The WTS was all good, the engine was warm (3 hours from home), I shifted to Neutral and Park until the shift arm warmed up. Luckily, I still had my dirty work clothes on and there was a freak warm wind, so under the truck I go. I found the electrical connector to the transmission wasn't difficult to remove, and it should have at least required me to unlock it. It was just held on by the friction of the weatherproof seal, but it wasn't latched. I checked to make sure the contacts were clean and I re-installed it, making sure it latched - I really had to press hard. Problem permanently gone.
Old 12-10-2011, 09:37 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is online now
Received 1,576 Likes on 1,054 Posts
Does the shifter feel loose and sloppy? If so, that's a common problem. There are two bolts on the underside of the steering column that come loose. They are a Torx 30 head. Look under the column not far from the floor. Add a drop of Locktite to each one and tighten them.
Explorer220K
04-01-2012 09:40 PM
proudfrog
09-05-2011 07:17 PM
jrchris
12-07-2009 05:31 AM
TurboTuff
15
05-27-2009 09:55 PM
Quick Reply: Truck wont start in park..Any ideas?
