Bronco II Ford Bronco II
Buying a 1988 Bronco 2. has fuel system problems. PLEASE HELP!!
Old 12-10-2011, 03:08 PM
Maverick1978's Avatar
Maverick1978
Maverick1978 is offline
I'm thinking about buying my buddys 88 Bronco II. There is a problem with the fuel system though. It gets power to the first fuel pump under the door, but doesn't get any power to the fuel pump in the back. It has a brand new fuel pump in the back, and a brand new computer in it. What had happened was that the tank had a leak, so they replaced the tank. Thus leading to the problem there is now. No power to the rear pump. I'm thinking it is probably just a broken wire.
Old 12-10-2011, 06:56 PM
Old93junk's Avatar
Old93junk
Old93junk is offline
Or the fuel pump relay, it's on the passenger side under a black cover about a foot behind the battery. Also try putting a jumper wire across the inertia switch connector (pass side under the dash on firewall).
Old 12-11-2011, 03:30 AM
crerar's Avatar
crerar
crerar is offline
If its like the same vintage Ranger, I think both pumps get power (or neither) off the ignition/relay/inertia switch circuit. So if the front (high pressure) pumps working but the back (in-tank) isn't getting power, I tend to agree you have a bad wire someplace 'twixt the inertia switch and the tank fuel pump:
have a 88 ford ranger with two fuel pumps one in the tank and - JustAnswer
has a wiring diagram towards the bottom
(maybe someone did some butcher wiring when the tank pump got replaced?)
Old 12-11-2011, 12:10 PM
Maverick1978
thanks guys. I'll try checking the wire with a tester when i go back up there. The bronco has the 2.9 V6 and manual trans. (if that helps) i'll try the jumper wire bit and see what happens. I am seriously thinking about the wiring though. But hey this is the best deal a 16 year old budget can find.
Old 12-11-2011, 12:16 PM
Maverick1978
But where do i hook the jumper wire to after i hook it up to the inerta switch? the fuel pump relay? and he said it has a new pcm too.
Old 12-11-2011, 12:25 PM
Old93junk's Avatar
Old93junk
The jumper wire you make, and put across the plug that goes into the switch..........leave the switch alone.
Old 12-11-2011, 08:20 PM
Maverick1978
ok. thats all i needed to know. thanks. and do yall know where i could find a patch panel for the cargo area behind the rear seat? they cut a huge hole out to get to the sending unit..
Old 12-19-2011, 09:45 PM
ldbill39's Avatar
ldbill39
ldbill39 is offline
B2 Fuel Problem
Check the ground at the tank, and in the wiring harness. The ground should connect to the frame piece right in front of the tank. I doubt it could be the inertia switch or relay, since the high pressure pump is getting power. As for the patch panel, your best bet is go to the junk yard and cut an oversized piece out of anther BII, and trim it to fit an inch over all the way around. Also, use either silicone or RV window putty to seal it. Good Luck!
Old 12-23-2011, 08:32 PM
Maverick1978
well i didnt get the Bronco. I ended up with a 1990 Ranger with the same 2.9. but an automatic.
crazed87bronco
1978 - 1996 Big Bronco
02-18-2009 02:05 AM
85B2Owner
10-23-2007 07:25 AM
aspen
04-10-2007 12:49 PM
greasymonkey
Electrical Systems/Wiring
02-21-2004 07:18 PM
RickT
Bronco II
10-25-2003 05:00 PM
Quick Reply: Buying a 1988 Bronco 2. has fuel system problems. PLEASE HELP!!
