STILL WORKING ON STUTTER- W/VIDS
[/B]Symptoms:<O</O
Stutter at 1500 and increases with RPM increase
<O</O
Here is what it is not--<O</O
It is not water in the IDM<O</O
It is not water in the PCM<O</O
It is not the connections of either IDM or PCM<O</O
It is not a ground<O</O
It is not a wire short<O</O
It is not a fuse<O</O
It is not a FBox relay<O</O
It is not a BATTERY<O</O
It is not the UVCWH<O</O
It is not the CPS<O</O
It is not the GPs<O</O
It is not the GPR<O</O
It is not the ICP<O</O
It is not the IPR<O</O
Or any of the connections - above<O</O
It is not the Starter/combo relay on the fender<O</O
It is not the ignition wiring or a short <O</O
<O</O
There is no chip nor DP tuner
<O</O
<O</O
So my options are---
Get IDM replaced or Try a reflash of the PCM<O
Not sure that either would work. Like I don’t know if the PCM reflash would do anything if it was a PCM issue.<O</O
<O</O
I don’t have a spare of either and don’t have anybody that has one around here to swap with.
<O</O
I don’t have a AE scan tool.
<O</O
<OBut code shown at first was * P0603 Internal Control Module KAM Error <O</O
And then after me piddling around this one showed up as well. * P0605 Internal Control Module ROM Error
<O</O
<O</O
So after working on it again today and still no success. I ran the codes again but they are clear since I have been working with the batts disconnected.
<O</O
<O</O
What I found- slight short in trailer harness-FIXED<O</O
One BATT with a DEAD short- REPLACED<O</O
Other BATT was old but passed load testing- REPLACED and replaced all glow plugs and left GPR off<O</O
<O</O
And since I was in the valve covers I replaced all wiring harnesses.
<O</O
So currently:<O</O
At idle no issues can be detected<O</O
At 1500 slight miss<O</O
Between 1500 and 2000 its still there but more rapid<O</O
Each Injector is spitting oil.<O</O
<O</O
THOUGHTS >>>> ???
<O</O
Here is some videos<O</O
CAB
REPS TO THOSE THAT CAN GET EM AND THOSE THAT CANT- YOU KNOW THE JAIL ISSUE. LUNCH TIME NOW--
EDIT---Forgot to add--- All Dealer service departments list replace PCM for those codes. Also the IDM relay was clicking rapidly before battery change out. Swapped it. I dont have a AE or other for the buzz test
<O</O
<O</O
<O</O
<O</O
<O</O
<O</O
<O</O
<O</O
<O</O
<O</O
<O</O
<O</O
<O</O
So currently:<O</O
<O</O
THOUGHTS >>>> ???
<O</O
CAB
THANKS MIKE!
Realy appreciate it Mike. I may take you up on that just to see what the heck it is. Here localy the IDM is 100 for a referb, but with Christmas on us and combined with supporting my Son and his family last month has drained my pockets quite low. Atleast they both are working again now and trying to catch up. I had to replace thier transmision last month darn I-Rodeo. New couple starting out with out much to start with. Whew.
I let you know in a day or so. To pay you back for the offer besides the rep sent. -- If you need any diagrams for your truck, let me know what you need with a pm and your email and I will see what I can do for you.
I know you say it is not the CPS, but have you tried another one from Ford or IH? Call me paranoid but that's always where I start on these intermittent issues. Also, check the wiring harness to the CPS real good as well looking for a chaffed or smashed wire.
EDIT: One other thing you could try (actually you may want to do this first) would be to clean out the TPS real good with some electrical contact cleaner. If the PCM sees a change in the reading from the TPS, it may not be a miss so much as it is a flutter in the speed as the PCM is calling for it. Another way you could check this would be to take it out somewhere and set the cruise control to hold the RPM's somewhere in the range where you are seeing this issue. If it doesn't stutter or miss with the cruise on, I would take a long hard look at the TPS.
THANKS NATE
Excellent call on the TPS I have not really checked it voltage wise, forgot to. Looked at it but not checked it. I would have thought that P0220 or P0221 DTC would have thrown. I also know that the pedal can get loose and cause issues I checked for that already. I will also check the IVS while I am digging around down there.
But the CPS and total circuitry there is in perfect order. Repa-doddle-do THANKS
Thanks again Rick
Yea I think its 1 volt or so at idle and 4 to 4.5 at WOT
Darn thing looks like new and I mean really new. I kinda doubt its the issue.
I am leaning more on the PCM opening the ground path on the IDM either from its on fault or a Inj fault. Strange thing is there is no frequency to it. Only noticable at 1500 to 2000 and I dont want to run over 2000 since the VC are still off. Splatters start at 2000.
But I am sure it would still do it above 2000
Obliged Nate
Nope, no AIC on it, dont really need it and the VC's are still off. It would not be too hard to pu em back.
