1994 F150 -- Dual Tanks, Front Tank Inoperable - Ford Truck Enthusiasts Forums
Old 12-10-2011, 12:18 AM
94150 94150 is offline
94150 is starting off with a positive reputation.
1994 F150 XLT 5.0L Auto -- 168k Miles
Hello, all!
The truck sat for quite awhile getting some "here and there" time spent on refinishing the body. Almost four years later, and the front tank that worked before no longer wants to cooperate with me.
I filled both tanks after the body work was finished and went on my way. I had left the switch on the rear tank through all of that time and did so until I flipped to the front tank a few days later and the truck went dead.
Sitting idling, driving, whichever... When the switch is flipped to the front tank, the motor dies.
To me, I say it's the fuel pump in the front tank. However, before I tear in and replace it, I want to make sure there are no other possibilities.
BTW, when the switch is flipped to the front tank, I can hear the pump come on with the key...
Thanks for any insight!
94 f150 fuel selector probs 94GreenTruck 1987 - 1996 F150 & Larger F-Series Trucks 4 05-23-2014 10:27 AM
Fuel from rear tank only tkisling 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 12-25-2013 10:47 AM
1994 F150 -- Dual Tanks, Front Tank Inoperable 94150 1987 - 1996 F150 & Larger F-Series Trucks 4 12-12-2011 04:54 AM
1995 F150 5.0 - Wont run on front fuel tank rlh68050 1987 - 1996 F150 & Larger F-Series Trucks 5 07-16-2010 03:55 PM
Front tank doesn't work and overflowing ac700wildcat 1987 - 1996 F150 & Larger F-Series Trucks 27 11-26-2006 05:12 PM
Tags
1994, 50l, 94, dual, f150, ford, front, fuel, inoperable, pump, recall, recalls, system, tank, tanks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
