what kind of transmission does a 97 f150 have? - Ford Truck Enthusiasts Forums
Old 12-09-2011, 07:43 PM
memphis_made's Avatar
memphis_made memphis_made is offline
memphis_made is starting off with a positive reputation.
what kind of trans do most 97 f150 4x4's with the 5.4 have? my trans recently wont shift it to 3rd or over drive so im trying to have a guy look at it but i dont know what kind it is and hed like to know b4 he comes out
Old 12-09-2011, 09:02 PM
Longdistancetrucker's Avatar
Longdistancetrucker Longdistancetrucker is offline
Longdistancetrucker is gaining momentum as a positive member of FTE.
Standard:5-spd man w/OD (Ford MTX-75 transmission)
Optional:4-spd auto w/OD (Ford AXOD transmission)
Old 12-09-2011, 09:34 PM
brokenleg brokenleg is offline
brokenleg has a good reputation on FTE.brokenleg has a good reputation on FTE.
5.4's wont have 5 spds. Its either going to be a 4R70W, or possibly a R4100......which is the HD one, but most have a 4R70W.
Old 12-09-2011, 09:45 PM
is the a place where i can type my vin in and it will tell me? and thanks for the help y'all
Old 12-09-2011, 09:54 PM
Quote:
Look at the door certification label.........it will have a code for trans.........but if your buddy doesnt know, be careful...
Old 12-10-2011, 01:29 AM
phil6608's Avatar
phil6608 phil6608 is offline
phil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant future
Not positive,but pretty sure.
97 & 98 5.4 had a E40D and 99 to 03 or 04 Heritage model had the 4R70
The 4.6 in all those years got a 4R70
Old 12-10-2011, 01:36 PM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
Correct it is an E4OD precursor to the 4R100. After '98 very few had the 4R100.
97 powerstroke mods? '97F-250Damien 1994.5 - 1997 7.3L Power Stroke Diesel 5 10-28-2015 08:05 PM
BAGGING A 97 F150 F150DROP Brakes, Steering, Suspension, Tires, & Wheels 0 11-02-2014 03:14 AM
97 f150 trans swap question 77-f250-Mud 1997 - 2003 F150 12 12-13-2011 10:41 PM
E4OD skips 2nd gear? GaneyB86 Clutch, Transmission, Differential, Axle & Transfer Case 10 01-10-2011 01:56 PM
79 Transfer case Fluid? louden Clutch, Transmission, Differential, Axle & Transfer Case 2 08-08-2003 08:26 PM
Tags
150, 1997, 2003, 42l, 4x4, 54, 97, codes, f150, ford, have, kind, transmision, transmission, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
