Go Back   Ford Truck Enthusiasts Forums > Misc. > Oil & Lubrication
Sign in using an external account
Register Forgot Password?
Oil & Lubrication NO MLM Dealers, Wholesale Buyers Or Retailers allowed (except sponsors)
SPONSORED BY:
  #1 (permalink)
Old 12-09-2011, 06:39 PM
pittmanjustin pittmanjustin is offline
Garage is empty, add now
pittmanjustin is starting off with a positive reputation.
79 f250 best oil
I just got a 79 f250 4x4 400 4spd its my first ford. What would be the best oil it doesnt smoke or leak anywhere and the factory oil gauge stays about halfway after warmup when cold its almost on the h thanks
  #2 (permalink)
Old 12-15-2011, 04:53 PM
77bigblock's Avatar
77bigblock 77bigblock is offline
77bigblock is starting off with a positive reputation.
I use Brad Penn 10w-30.
__________________
Ryan
77 F250 Custom 4x2 w/460
78 F100 Custom 4x2 w/300 (retired)
77 F250 Ranger XLT 4x2 w/460
92 F250 Custom 4x2 w/351W
  #3 (permalink)
Old 02-13-2012, 08:54 AM
spastik monkey spastik monkey is offline
spastik monkey is starting off with a positive reputation.
Any full synthetic 10-30 should do ya fine. If you looking to pick up some fuel economy and it don't get too hot where you are, go with a 5-30 synthetic.
  #4 (permalink)
Old 02-15-2012, 09:37 AM
jimandmandy jimandmandy is offline
jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.
Your profile says MS for state of Mississippi, correct? Then cold starting and the main advantages of full synthetic are wasted, unless you want to greatly extend drain intervals. "Any" full synthetic wont have more zinc to protect the flat-tappet cam than conventional oil. Since Brad Penn is a "boutique" conventional product that you need to mail order, making the net cost high. Might I suggest some alternatives that are available at most any local auto parts store. Chevron Delo 400, Shell Rotella T, and others have 1200ppm zinc and usually retail for way less than $20 a gallon. There are synthetic versions of those oils also, for around $30 a gallon. The other alternative are European car formulas of the better-known expensive full synthetics. Castrol Syntec ONLY in the 0W-30 grade is one of the best. Mobil One EP or European Car Formula (only) is another exellent choice.
  #5 (permalink)
Old 02-15-2012, 03:42 PM
dkf's Avatar
dkf dkf is offline
dkf is a name known to alldkf is a name known to alldkf is a name known to alldkf is a name known to alldkf is a name known to alldkf is a name known to all
A 15w-40 Rotella or Delo is a popular oil for these engines due to the higher levels of zinc and phos. I've been running 10w-30 full synth in my original (never touched from factory) 74' 302 with good results but I'm up the northeast and the engine was gunky from sitting a lot of years. The next change will be with a 15w-40 Chevron Delo because I don't drive it much anymore and want to cut down on oil change costs vs a full synthetic. If I remember correctly a 5qt jug of Delo at wally world is in the $14 range.
__________________
With the wrong tires and the right idiot any truck can get stuck...
  #6 (permalink)
Old 02-20-2012, 10:29 PM
tbm3fan's Avatar
tbm3fan tbm3fan is offline
tbm3fan has a very good reputation on FTE.tbm3fan has a very good reputation on FTE.tbm3fan has a very good reputation on FTE.
I just read somewhere that the HDEO lubes are now at 1100 ppm for zinc today. Also read a Shell paper about who really needs to use the higher zinc and who doesn't. My 302 with high lift cam and double springs needs VR1 Valvoline for sure. My original 1972 360 doesn't need the 1100 ppm level. Besides the zinc declines with the age of the oil and with an oil change once a year at 2000 miles I have no worries.
Since I live in a region where my older vehicles, when used, will run between 45-85F I don't need a synthetic. I have used Penzoil Platinum in several engines to help clean out the engines since the vehicles were never originally owned by me. That was the only purpose. When they are done I put in a 5W-30 SN oil in 6 of my 8 vehicles. I want quick start up flow, after sitting, and then need only -30 at operating temperature in my region. Penzoil yellow 5W-30 has one of the highest zinc levels for an SN rated oil along with the phosphorus. Also a decent TBN and Viscosity Index.
As for the HDEO oils, such as Delo, Rotella or Delvac, I have never seen them in 5qt. jugs. I have a Chevron distributor 5 blocks from me for 10W-30 and he has no 5 qt. jugs in his inventory.
__________________
Mike
1965 F-100 360-2V
1968 Cougar 302-4V
1968 Mustang 289-2V
1967 Parklane 410-4V / 1973 Dodge Polara
1943 USS Hornet/1945 TBM3E Avenger
  #7 (permalink)
Old 02-21-2012, 02:31 AM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
The only HDEO that comes in 5 quart jugs is the Motorcraft 15w40 the rest come in 1 and 2.5 gal jugs.
  #8 (permalink)
Old 02-21-2012, 09:19 AM
dkf's Avatar
dkf dkf is offline
I just double checked the Delo I have and it is a 4quart jug. I'm so used to buying 5qt jugs for the other vehicles an its pretty much the same size so I thought it was a 5qt jug. My bad.
__________________
  #9 (permalink)
Old 02-23-2012, 10:26 AM
Rotella T, both conventional and syn, as well as Delvac 1300 Super are now on sale at O'reillys in gallon jugs. $20 a gallon for full syn is quite a bargain. We even race motorcycles using Rotella T6 5W-40.
Tags
360, 400, 5w, 74, 79, big, block, engine, f250, ford, heavy, kind, oil, pulling, type, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
