Replacing ignition key lock cylinder.... - Ford Truck Enthusiasts Forums
Old 12-09-2011, 06:10 PM
Lebowskii's Avatar
Lebowskii Lebowskii is offline
Lebowskii is starting off with a positive reputation.
I just spent at least an hour going through old threads and I'm still confused as to how to do this. I have a '95 F150 4x4 regular cab longbed with the 4.9L 6, manual transmission, and no tilt wheel. I can drive the truck as it is now but the end is broken off the lock cylinder and I'd like to put on a new one. The instructions say to disengage the air bag and remove the steering wheel. Is that necessary? I stuck a screwdriver up the hole but couldn't find a pin to release the old cylinder. Is there a trick to finding the pin? Should I try to drill out the old cylinder? Any advice would be appreciated....
Old 12-09-2011, 06:15 PM
bashby's Avatar
bashby bashby is offline
bashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to all
Turn the key to on while pushing the pin. Look at the new part to figure out exactly where the pin is and how small of a tool you need to do it.
Old 12-09-2011, 06:20 PM
danr1 danr1 is offline
danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.
Not sure why the instructions are telling you to remove the wheel, should just need push the release button to pull it out. Unless they changed something between 94 and 95 or something in the air bag system made a change. Gotta say I doubt it.
Remove the lower column cover so you can clearly see the release button, turn the key to "run" push the button and pull the cylinder out.
The new cylinder should be in the run position right out of the box, if not turn it as so it is, push it in and it will lock in place. Should work like new second you have it locked in.
Old 12-09-2011, 06:23 PM
White 97 xlt's Avatar
White 97 xlt White 97 xlt is online now
White 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputation
X2 As simple as can be!!!!
Old 12-09-2011, 06:25 PM
Edgethis's Avatar
Edgethis Edgethis is offline
Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.
I just did this on my 95. You do not have to remove the wheel or airbag.
Note: Do NOT turn the new cylinder in your hand, there are little pins that will shoot out if you do.
Turn your current key to on/acc (like listening to radio), then push a screwdriver (small Phillips works best) up the hole directly under the cylinder on the column, while pushing up on the pin, pull the entire assembly out. Installation is just sliding new cylinder in once its removed from the tube it prolly came in.
Old 12-09-2011, 06:28 PM
Seams I recall something like that but never actually turned one, cylinder is ready to go in right out of the box (Unless someone played with it of course).
Old 12-09-2011, 07:11 PM
Lebowskii's Avatar
Thanks for the comments and advice. I'll give it a try tomorrow morning and let you guys know what happens. Is it really necessary to remove one of the battery cables first?
Old 12-09-2011, 07:17 PM
bashby's Avatar
No need to disconnect battery.
Old 12-09-2011, 07:20 PM
Quote:
While probably not 100% necessary, I would because you never know what will go kerflewie!!!! Better take a minute and be safe than hurry and have a major screw up...
Old 12-09-2011, 07:44 PM
Lebowskii's Avatar
Will removing a battery cable prevent the possibility of the air bag exploding in my face?
Old 12-10-2011, 03:58 AM
MintFord's Avatar
MintFord MintFord is offline
MintFord is starting off with a positive reputation.
You must to let the vehicle sit for 10 minutes after the battery is disconnected before there is no chance of airbag deployment.
Old 12-10-2011, 04:09 AM
SideWinder4.9l's Avatar
SideWinder4.9l SideWinder4.9l is offline
SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.
Quote:
Guess who found this lil tidbit out like .000000000000000000000000000000001 miliseconds before my buddy told me NOT to turn that damned key....Then...PIIIINNNGGGGGGG.......I FINALLY found those lil buggers....
Btw...Mine is kinda funky to turn, and he gave me a OEM one from he picked up from a yard...and it had the MOTORCRAFT/OEM Ford key IN IT
So yeah....Awesome in its own right....
Old 12-10-2011, 02:27 PM
Lebowskii's Avatar
Success!
Dan's tip of removing the lower plastic piece helped a lot. I used an ice pick in the hole while pulling on the lock cylinder with needle nose pliers and it came out easily. The key would just slide out so I probably could have started it with a screwdriver. I had my wife start it a couple of times and she's much happier with it now. (She has a small flower business and occasionally uses the truck to haul 40-100 vases of flowers for various luncheons.) Thanks again to all who shared their knowledge and advice. This is a great site....
Old 12-10-2011, 02:31 PM
Edgethis's Avatar
Glad to hear you got it swapped out.
Old 12-10-2011, 11:19 PM
Plain Jane Plain Jane is offline
Plain Jane is gaining momentum as a positive member of FTE.
Success is a beautiful word!
1992 aftermarket lock cylinder install - will not fit Camuchi 1987 - 1996 F150 & Larger F-Series Trucks 4 04-11-2016 08:46 PM
Hot to replace key lock cylinder in 1993 Ranger? Outspoken1 Ranger & B-Series 4 12-29-2015 09:13 AM
ignition cylinder removal w/ no key fordtrck302 1987 - 1996 F150 & Larger F-Series Trucks 17 12-06-2015 06:21 PM
Ranger 10" Brake Link Pins aj197816134 Ranger & B-Series 3 05-03-2014 02:59 PM
Shift Lever Moves but Doesn't Engage (spring Pin?) skippr76 1987 - 1996 F150 & Larger F-Series Trucks 4 02-20-2008 04:33 AM
Tags
1983, 1994, 95, 96, cylinder, exploded, explorer, f150, f250, grand, ignition, image, ingnition, key, lock, marquis, mercury, replace, replacing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
