clicking noise when accelerating or slowing down. HELP
Old 12-09-2011, 01:35 PM
McKenzie7.3's Avatar
McKenzie7.3
McKenzie7.3 is offline
okay so i have a clicking noise when i accelerate or let my foot off the pedal, there is no noise in neutral or when i push the clutch in, sounds like its coming from the transfer case but im not sure, has anyone had this problem??
Old 12-09-2011, 01:39 PM
plumber01's Avatar
plumber01
plumber01 is offline
You could start simple by checking the fluid in tranny or see if the filter needs attention. But I'm sure if you wait a little, someone will chime in with some actually good advice ha ha ha ha ha.
Old 12-09-2011, 01:40 PM
plumber01's Avatar
plumber01
Wish I could be more help
Old 12-09-2011, 02:40 PM
Shanejet's Avatar
Shanejet
Shanejet is offline
You might look at your U joints. They typically squeal when they go out, but clicking is a possibility. When you are in neutral or clutch in there is very little load on them. Do they click less at highway speeds?
Old 12-09-2011, 08:24 PM
KJNDIVER's Avatar
KJNDIVER
KJNDIVER is offline
I see new u-joints in your future.
Old 12-12-2011, 01:07 PM
McKenzie7.3
i have only driven it about 30km since the clicking started, i did drive down the highway and couldn't hear the clicking, but i don't no if that's just because of tire noise ect. the noise is really noticeable taking off in 1st and second. like i said originally it sounds like it is coming from behind the transmission but hard to tell from the driver seat. im going to put the truck on jack stands and put it in gear and see if i can pin point were the noise is coming from exactly, the noise i guess. if it is the u joints is it safe to drive for a couple days?
thnks for the help!
Old 12-12-2011, 02:02 PM
HH60FE's Avatar
HH60FE
HH60FE is offline
hey McKenzie, we aren't a bunch a safety ****'s here but it sounds like your getting ready to do something kinda scarry. Please use caution if your gona do what i think your gona do.
Oh, welcome to FTE.
Old 12-12-2011, 04:31 PM
Shanejet's Avatar
Shanejet
Shanejet is offline
If you put your truck on jack stands you will be taking most of the load off the ujoint. If your u joints are serviceable, just grease them and listen for the noise. If the noise isn't bad you may not feel any play at the driveshaft. They will get worse and can leave you stranded but you should be able to make it to the next day off. Or you could just take it in to a shop.
Good luck and keep us posted.
Old 12-12-2011, 04:37 PM
Shanejet's Avatar
Shanejet
Shanejet is offline
Sorry, just looked at your rig specs. How is your driveshaft angle with the 6.5" lift. U joints could be binding. That will definately cause a click. Has the lift been on awhile?
Old 12-13-2011, 12:36 PM
McKenzie7.3
thanks, i still haven't had the time to investigate anything yet but im going to see what i can figure out today, my u joints aren't serviceable which is kinda stupid. and the angle on the drive shaft from the lift isn't to bad,and yea it has had the lift for a while. thanks ill keep u posted on my findings haha
Old 12-13-2011, 01:12 PM
PaysonPSD's Avatar
PaysonPSD
PaysonPSD is offline
You haven't told us your trucks configuration so if you have a two piece rear drive shaft check the carrier bearing.
Old 12-18-2011, 12:06 PM
McKenzie7.3
okay, so i have a 2 peice driveshaft that has one u joint at the back and two at the front, when i got some time i checked it out and wiggled my driveshaft around and sure enough it was one of the front u joints or both, or so i thought. i went down to lordco and bough the two u joints and replaced them, once i had the driveshaft together with the new u joints i moved it around a bit to find that replacing the u joints was not the issue, so it must be the coupler inbetween the u joints
thanks for anyones help
EQCMCAT
08-02-2017 10:44 AM
Rosco71287
04-14-2013 01:00 PM
76f1390
1983 - 2012 Ranger & B-Series
12-03-2007 08:23 AM
straightexhaust
12-16-2006 05:45 PM
Judson4.9L
06-13-2005 08:42 PM
Quick Reply: clicking noise when accelerating or slowing down. HELP
