Ignition Coils
I just bought one at Carquest that is labeled 12 volt...and..it is clearly printed on the coil not to use a ballast.
I think I would have preferred an external ballast type because the solenoid can provide 12v during starting for a hotter start. It doesn't seem to be much of an issue.
One benefit of the external ballast is that if you ever leave the key "ON" with the engine not running....and the points happen to be closed, the ballast will heat up and increase resistance....that will protect the coil to some degree.
Dan
Dan
MercM47
03-02-2005 11:05 AM
