Gasket set Recommendations 7.3 IDI Sealed power or Fel-Pro - Ford Truck Enthusiasts Forums
Old 12-09-2011, 10:00 AM
kb1jid kb1jid is offline
kb1jid is starting off with a positive reputation.
Hi Id like to replace the gaskets and seals in my 7.3 before I install it into my 1990 E250 van I can get Sealed Power set or Fel-Pro set any Recommendations?? I have used fel-pro before on gas engines with no problems both sets are about the same $$ Thanks Bob
Old 12-11-2011, 08:05 PM
jimbbski jimbbski is offline
jimbbski is starting off with a positive reputation.
I would post this in the diesel section of this forum, you'll get better responses.
BEST gasket vs. FEL-PRO gasket 1964FORDTUF 1961 - 1966 F-100 & Larger F-Series Trucks 3 07-12-2015 06:16 PM
1997 Ranger 4.0L Valve Cover Gasket Replacement Leak Troubleshooting (w/ Pics) Bob K. Ranger & B-Series 14 05-27-2014 09:33 AM
E40D - OEM Trans gasket....rubber or cork? SoCalAngler 1987 - 1996 F150 & Larger F-Series Trucks 37 04-22-2014 09:46 PM
Do I need gaskets for the intake with a vally pan? f250custom78 1973 - 1979 F-100 & Larger F-Series Trucks 5 10-17-2012 09:27 PM
FEL-PRO Gasket Set Scout Pilot 1961 - 1966 F-100 & Larger F-Series Trucks 3 04-11-2012 04:10 PM
Tags
73, 73idi, engine, fel, felpro, ford, gasket, gaskets, idi, power, pro, sealed, set, sets, vs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
