Last night my front axle gears crapped out, it has a dana 50 ifs, I have found a front axle off a 94 f350 dana 60. I have not found anything and wondering if and what it would take to do a swap to a solid dana 60?
In my opinion, any time you try to change things, you run into problems. If I were in your position, I'd probably just buy a new ring and pinion and rebuild the thing with new bearings and seals.
I bought a dana 60 off a 94 f350, to put on my 97 f250. I need the track bar, sway bar, and the driverside bracket that the u-bolts and sway bar bolts to by the pumpkin. I did get those parts from a 2001 f250 but I am not sure if they will fit. Any help is great. Thanks
If they don't fit, I have the track bar bracket that mounts to the frame crossmember. It's the stock one. I also have a sway bar that I don't plan on using, but shipping on that would be pricey. PM me an offer if you need it.
I can tell you that the superdutys have wider frames; so I would tend to think that the track and sway bars will be too long. But you could probably make the drivers side U-bolt bracket work. The track bar bracket I have could be shipped fairly cheap if you're interested.
Well last night a friend of mine located a 97 f350 dually 4x4 that is wrecked, I plan on looking at it tomorrow night and see what is good and price. That way I know I can maybe unbolt whole front end and just replace the hubs and rotors out.
