Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 12-08-2011, 10:56 PM
rayofsi rayofsi is offline
Garage is empty, add now
rayofsi is starting off with a positive reputation.
Rust inside the car, is this normal?
So i have rust inside the expedition, this is a 2011 model, made 12/2010, but recently purchased 12/2011. IMAG0480.jpg picture by ufokillerz - Photobucket is this normal?
  #2 (permalink)
Old 12-08-2011, 11:51 PM
kennisonxgs kennisonxgs is offline
kennisonxgs is starting off with a positive reputation.
Looks like every car I've seen. It's normal.
  #3 (permalink)
Old 12-09-2011, 11:11 AM
Johnny Law Johnny Law is offline
Johnny Law is starting off with a positive reputation.
Normal. Mine is a 2011 built 5/11 purchased in 6/11. Looks just like yours. Looked under my '96 Suburban and there is some there too but not as much as it doesn't have the same cross plate visible but it is on the Steering column and some other brackets.
I would bet you wouldn't see this on a Mercedes, Lexus or Porsche. I think for the price that we pay for these vehicles there is margin to throw some paint at things under the dash.
But what do you do...
  #4 (permalink)
Old 12-09-2011, 11:17 AM
thanks for confirming, this is my first american car, my previous cars were a mercedes and a bmw, but with this economy, i decided to keep money in the bank and go with something big and comfy, and economical. was very surprised to see the rust
  #5 (permalink)
Old 12-09-2011, 12:59 PM
Ramlock's Avatar
Ramlock Ramlock is offline
Ramlock is starting off with a positive reputation.
Where are you located?
  #6 (permalink)
Old 12-09-2011, 01:02 PM
new york city area, expedition came from a dealer in long island.
  #7 (permalink)
Old 12-09-2011, 01:12 PM
Ramlock's Avatar
Quote:
Yea, then I would say normal
  #8 (permalink)
Old 12-10-2011, 04:12 PM
Tylus's Avatar
Tylus Tylus is offline
Nuke Mechanic
2006 Ford F-250
Tylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud of
doesn't matter where you get the vehicle from. it's simple surface rust from untreated/covered metal
the dash underparts will never see water other than moisture in the air. So they'll never rust out. The rust you are seeing is actually a protective layer. It will never get any worse as the current layer prevents further oxidation
hate to break your bubbles guys, but you'll find this on every single vehicle, Foreign or Domestic. The High End imports usually have more flashing/plastic that hides this, but it's there. No point painting something that doesn't need it
__________________
MM1 (SS) - 688 Class - First Flight Tough
2006 F-250 Lariat CC w/PSD <-- Build Thread
2012 Flex Limited <-- 17 mpg city, 27 mpg highway.
  #9 (permalink)
Old 12-10-2011, 04:24 PM
Thanks Tylus, i'm just wondering, is rust in the underside of the body, axle and other solid metal pieces normal? i have a crazy amount of that under the car as well.
  #10 (permalink)
Old 12-10-2011, 04:43 PM
Tylus's Avatar
Nuke Mechanic
2006 Ford F-250
rust on the frame and axles and other solid chunks of metal is normal
if you live in the south, I wouldn't worry about it.
if you live up north, especially in Salt country, I would look at a product like Por15 or some other undercoat and cover the exposed metal. Short term the undercarriage will be fine, but multiple winters with salt will wear away the metal and in extreme case eat through it.
if you undercoat, make sure to avoid leaving pockets that water could get trapped into...ie: between body panels, in the pinch welds. if water gets trapped in there, it will accelerate the rust issue
__________________
  #11 (permalink)
Old 12-15-2011, 11:03 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
I concur with Tylus on the Por15. Use the 3 step system and follow the directions. It's really quite amazing. The prep is not bad at all. Just be careful with the paint, it's the stickiest paint I have ever seen and is hard to get off if you spill.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #12 (permalink)
Old 12-15-2011, 11:08 AM
i will definitely look into the por 15, but not sure if i can apply it before the snow hits this season, the weather is definitely not the warmest, and if por 15 is anything like paint, chances are it will never completely dry in this weather either.
  #13 (permalink)
Old 12-15-2011, 11:27 AM
berry1234's Avatar
If you can get it into the garage, let the area dry, you can apply the whole process in a few hours. Leave it in the garage-heated I hope-for a day you should be good.
__________________
  #14 (permalink)
Old 12-15-2011, 11:41 AM
expedition definitely doesnt fit into my garage, the garages in the new york city region were built rather small.
  #15 (permalink)
Old 12-15-2011, 11:45 AM
berry1234's Avatar
Well then you can wait until summer. One more season won't make much difference.
__________________
Tags
2008, auto, car, expedition, find, ford, frame, inside, interior, normal, rust, rusting, surface, trucks, vehicle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
