1991 F150 Key Problems - Ford Truck Enthusiasts Forums
Old 12-08-2011, 08:50 PM
Larzon Larzon is offline
Larzon is starting off with a positive reputation.
I recently got a 1991 Ford F150 4x2. I got it for $200 expecting some problems. Just not one this big.
Problem:
The truck starts just fine, idles fine, everything works flawlessly. When I go to shift into drive the engine kills but leaves every accesory on.
Anyone have any clue what is causing it to kill? Any help would be appreciated.
Thanks,
Alex
Old 12-08-2011, 09:50 PM
Plain Jane Plain Jane is offline
Plain Jane is gaining momentum as a positive member of FTE.
state engine type, and transmission type. does it also die if you shift into neutral or reverse?
Old 12-08-2011, 10:42 PM
The truck has the Inline 6 with a Auto transmission. Yes it kills when trying to shift into anything. The key is super sensitive. If you just tapped the key the engine will shut off. It will also shut of if you grab the steering wheel when getting out or in the truck.
We brought it to the one of the local shops for the brake lines and they said that the ignition cylinder lock or switch is worn.
Old 12-08-2011, 10:58 PM
REAPER4206969 REAPER4206969 is offline
REAPER4206969 is starting off with a positive reputation.
Quote:
I had to replace mine in my '90, it's easy.
Old 12-08-2011, 11:29 PM
Quote:
Did the switch but I am having the same problem.
Old 12-09-2011, 12:36 AM
Did you change the cylinder and key?
That's what I did.
Old 12-09-2011, 12:48 AM
Rebuild101 Rebuild101 is offline
Rebuild101 is starting off with a positive reputation.
Look for a bear wire or loose connection in the column
Il bet that's what you will find
I had the same deal
Old 12-09-2011, 05:10 PM
it the key is loose in the ignition lock cylinder then it is probably a bad connection in the cylinder that is getting jostled around when you shift. There is a link about changing the lock cylinder somewhere on the site if you search under ignition lock cylinder replacement or some variation, they new cylinders are around $20 so it is not a huge deal. If the problem persists then you will have to start tracing connections, not a huge deal but time consuming, Good luck! Just a thought, is it the original key from 91 and is it really badly worn? I just replaced my original key, it was so worn that I was worried about it snapping or bending, the new key seems to fit everything better with less wobble in locks and ignition.
Old 12-10-2011, 07:00 PM
We switched the key but what is happening is that the key doesn't stay in place after I start it and let go. In order to even shift it into gear, I have to hold the key in place.
Bare with me I'm 15 and don't know the right terms.
Old 12-10-2011, 07:15 PM
danr1 danr1 is offline
danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.
Sounds like you're suffering the actuator problem and or have a problem with the ignition switch itself. All spring action in the key cylinder originates from the ignition switch via the actuator rod.
Search the forum here for threads/posts about "actuator" and you get more then enough hits to aid you in what you need do.
If you just can't find it post back someone will help ya out directly.
1991 F150 won't shift into Low Range. Duncansm 1987 - 1996 F150 & Larger F-Series Trucks 14 06-06-2014 07:00 PM
1991 F150 cbmule 1987 - 1996 F150 & Larger F-Series Trucks 8 02-11-2014 06:05 PM
1991 F350 7.3 stalling jduggan43 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 09-30-2013 11:29 AM
1991 f-150 acts like it is running out of gas redmom74110 1987 - 1996 F150 & Larger F-Series Trucks 8 02-25-2008 10:14 AM
1991 F-150 Lighting Problems calvinlc 1987 - 1996 F150 & Larger F-Series Trucks 8 08-06-2003 04:34 AM
Tags
150, 1991, 91, dosent, engine, f150, key, kills, stay
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
