Coolant leak!!!
Old 12-08-2011, 07:24 PM
jayc3169's Avatar
jayc3169
jayc3169 is offline
Coolant leak!!!
I've narrowed the leak down to the front of the motor above the lower radiator hose. Kinda front and center of the motor. I would say water pump but Just changed it. The top of the motor is dry. Changed my water pump about 1000 miles ago. She's leaking pretty bad. Even when engine is off she's still leaking. Any suggestions?
Old 12-08-2011, 07:41 PM
jayc3169's Avatar
jayc3169
jayc3169 is offline
Heat still works by the way!
Old 12-08-2011, 07:46 PM
BLADE35's Avatar
BLADE35
BLADE35 is online now
how about the thermistate and or the heater line right where it turns from metal to rubber at that connection in the front
Hate to see it be a bad water pump gasket but you never know
another thought was a pinhole leak in the radiator spraying coolant into that area
Old 12-08-2011, 07:48 PM
jayc3169's Avatar
jayc3169
jayc3169 is offline
I checked all hoses, but I'll double check. and I got a good look at the radiator, but again I'm double checking everything in the morning.
ruschejj
6.7L Power Stroke Diesel
08-12-2012 12:01 PM
Powerhouse ABO
07-05-2012 05:20 PM
tshrager
16
05-21-2012 05:49 PM
David O.
05-01-2005 11:20 PM
bpetriw
Aerostar
09-04-2004 09:35 PM
Quick Reply: Coolant leak!!!
