Purple power for coolant flush?
I've got my oil cooler and egr delete kit ready to install, obviously I have to drain all the old coolant out and do the flush and fill technique before I replace everything. I read the tech article on the chemicals you're supposed to use like VC-9, Fleetguard restore, etc. Someone told me I should use purple power degreaser (diluted of course) along with water to flush out the system, but more than likely I will use Fleetguard restore. Is purple power even safe and/or dependable to use when flushing the cooling system in a case like this?
2004 ford f250, 6.0 4x4
I use it to wash the truck on the outside...not sure about on the inside of the coolant system. The only reason you'd need a degreaser in your coolant system is if you've had an oil cooler pop. Otherwise the VC9 will do everything you need. You may need to back flush the system after the VC9 because there's a chance it going to knock some crap loose. There have been guys report having their oil cooler fail within a short time after doing a coolant flush.
http://www.fleetguard.com/pdfs/produ...LI33024-GB.pdf
pop
@Maxium4x4: Ok, well the coolant is slightly brown. Not sure if that reflects the actual amount of contamination in the system but regardless, sounds like i'll be undertaking the project this weekend and picking up some real good degreaser at wal-mart today.
@Dieselpop: I actually discovered the coolant looked unusually darker last week and noticed a thin film of that oil shine on the surface of the coolant. That was enough for me to ground my truck in my garage. It's not a substantial change in color, it just has a darker tint so I suppose the leak's not too bad.
I've never heard of anyone having to remove their radiator to get it clean. But I guess if you really wanted to spend the time to take the truck apart...go for it Personally I'd dump as much coolant out of the truck as I could; and start flushing with a degreaser; then VC9; then back flush to keep the crap from plugging the new oil cooler. Several folks have done that in the past and it worked for them; and when the time comes that's what I'm going to do to my truck.
If you can do an egr delete that would be good and a good place to get parts 2005 Parts - Tousley Ford Parts Depot for an oil cooler and get a good set of gauges ScanGaugeII or Edge Insight CTS they are needed in a 6.0 for many reasons.
other places
BulletProofDiesel - Darn-Near Bullet Proof Diesel Products for your 6.0
GoGoDiesel EGR Delete System The most advanced EGR delete system for your 6.0L Powerstroke.
This may help
NT Shoptools.com, Mesa
pop
other places
This may help
pop
pop
@Zhilton: Yeah, i'm not sure if i'm going to actually remove the radiator or not (although i've done it before it's a bit*h) because the leak isn't too bad, i'll just have to see how much time I have, most weekends for me are 95% free
@Dieselpop: I bought an EGR delete kit when I got my oil cooler last week and I plan to get gauges after I get everything put in. One of which is definitely going to be EOT
