I beam Differences
I beam Differences
As of late I have been having a hell of a time getting my 1992 ford bronco aligned. I think the reasoning behind this is because when i gave my bronco a pro comp 4" inch lift I mismatched some front end pieces, the I beam arms are from a 1980 f-150 and the knuckles are from my 1992 bronco. I have done as much research as possible and have not been able to see if ford changes the geometry of the ball joint mounting holes from 1980 till 1992. I have a 4 inch lift with extended radius arms. My alignment shop put in 2 and a half degree shims to align it on the top ball joints. The ball joints look to be really stressed and i have a feeling they wont last very long.
So does anyone know if there are geometry differences between 1980 I beams and 1992 I beams? I may have to pick up some 1992 I beams.
andym
11-30-2005 02:13 AM
1990F2504604x4
11-29-2005 06:53 PM
kjett
05-07-2004 03:26 PM
