Excursion Roof Rack Modifications
#137
#139
Hey guys,
I am bringing back an old but very valuable thread..... I love all the ideas here on roof racks. I am going to start doing some CAD drawings tomorrow but I have a few quick questions. I am leaning towards pulling the whole stock rack and going with angle iron idea. For those that have done this, did you go with a lighter gauge angle like 1/8" or smaller so that it contoured to the overall roof (except in front where the roof drops), or did you just make it rigid and totally flat and let the roof push flat. Also by "hard point" connectors are you guys referring to the stock bolt points? or are you guys drilling and through bolting?
Over all, I am building the truck to haul my camper, 1 canoe, 1 kayak, and 5 bicycles. I definitely want it flat and full length like ExploringNH's old rack minus the front drop down. this way I can add the J_bars for the kayak and get the canoe up and down with "limited" ease!!! I am coming from an f350 crew cab full bed, so i am still trying to learn to pack lighter!!! My kids are still super young so we bring EVERYTHING!!I want to be able to toss the generator, portable water tanks and waste tank up there too.
thanks for any suggestions offered..
#140
This is not the angle iron method, but was simple to assemble and has held up well. Easy to gather parts and utilizes the factory rails with no drilling necessary and is really sturdy and flexible for turning into a rack or attaching a rack to these crossbars.
Hardware store crossbars
#141
Rubber spacers under stock Roof Rack
thanks to someone on this forum I went with the cheap and easy mod to my stock roof rack. found some scrap rubber, cut it with my circular saw, drilled and installed with longer 6 x 40mm metric cap bolt. worked great. repainted the stock rails and cross bars flat black. just need to find a couple more of the screw on parts that hold the cross members on. here is the spec on the rubber, i'll put up pics as soon as i figure out how to...
60 durometer skirtboard rubber, 1" thick, blended SBR/NR slit sheet , plate finish. Styrene/butadiene and isoprene rubber, natural. SBR/NR
The following users liked this post:
#143
F250Rob
20
08-28-2004 09:41 PM
