1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
schrader valve pressed fuel dribbled
Old 12-07-2011, 06:47 PM
kalpesh's Avatar
kalpesh
kalpesh is offline
i just poked the schrader valve, fuel just dribbled out a bit, not a flow or no pray is this normal or low?
Old 12-07-2011, 08:53 PM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
That is not good! I suggest that you replace your fuel filter and if it does not have about 35psi the fuel pump may have gone bad.
Old 12-07-2011, 08:55 PM
kalpesh's Avatar
kalpesh
kalpesh is offline
i tested the valve without anyone cranking it, wonder if that makes a differences, i would turn the key a few times, and then push the valve and dribble, none the less its started, i have a ford fuel filter in tow and its off to a shop
Old 12-07-2011, 09:16 PM
D-Cell_Mekanick's Avatar
D-Cell_Mekanick
D-Cell_Mekanick is offline
Cycling the key will run the pump. If there is no pressure then pump is suspect.
86f350
41
12-11-2012 10:01 PM
87 Ford Driver
03-03-2011 10:16 AM
douglascwilliams
1983 - 2012 Ranger & B-Series
01-27-2008 09:18 PM
dzzavid
25
12-07-2007 01:23 PM
kjoy1
09-09-2004 11:52 PM
Quick Reply: schrader valve pressed fuel dribbled
