Champion vs. OEM plugs
Couldnt find a post about this so I'm starting one. Sorry if its been beat to death somewhere else.
I recently came across a website saying the Champions were a better alternative to the OEM spark plugs because they dont have the potential to leave the sleeve in the head... while I dont believe that completely they are a cheaper alternative. Does anyone have any experience using these?
I'm also assuming that my '08 which was built early '07 still has the problem. I only have 28k KM's on it but thought better safe than sorry and AI'm unrealistically hoping that my fuel mileage might climb up from 8MPG...lol
Thanx folks!
Thanx folks!
I did a ton of research on this only to find out both my trucks have the new style heads. However, what I learned is the change is engine production date of around 10/09/07 (look for the sticker on drivers side valve cover) the plug boots that are under the COPs and go into the head are dark brown instead of black. Prior to learning this, the “game plan” I came up with for living with the two piece plugs included always burning Cheveron ( or any top tier) high test, running sea foam in the gas once a month, making the first plug change at 30,000 and subsequently changing the plugs every 40,000 (because of putting the anti seize on the long sleeve). As far as one piece replacement plugs, there is an additional option of the Brisk racing plug. http://www.briskracing.com/content/tech_spec.php Their plugs come in a variety of heat ranges to allow for superchargers, turbos and such on the other modular engines. They will fit the v10 as well. Their web site doesn’t seem to be working very well right now, I don’t know why that is. That’s about all I know. Good luck.
